Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-17-2008, 10:58 PM
playurr playurr is offline
timing cover leaking anti freeze
I have a 1999 dodge ram 1500 5.2L . theres a slight leak of anti freeze coming from the timing cover area, didnt even know there was anti freeze around there, anyone else ever have this problem? Took it to a shop and they gave an estimate of $700.00 to replace the timing cover gasket, is this for real?
Old 03-18-2008, 03:08 AM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
Re: timing cover leaking anti freeze
Did you tell them to put on a timing cover gasket or fix the anti freeze leak? They will do (AND CHARGE YOU) what you ask if it is your diagnosis because if it does not fix your problem they don't care. They did what you asked them to do. Try asking them to fix the antifreeze leak and see if they tell you it is the timing cover. My guess is it would more likely be a water pump leak dripping from the cover.
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold)
HIS----> 2003 Dodge 1500 HEMI QC 4X4
Old 03-18-2008, 10:04 AM
jpb53 jpb53 is offline
Take a close look at the thermostat housing gasket always a problem and kind of hidden.
Old 04-05-2008, 07:00 AM
fanworks fanworks is offline
I just had this happen with my 1992, the seal between the engine block and the timing cover gave out.
Let me tell you this, its a pita to replace. The process took me a week to do in my driveway between tearing it down, pulling the oil pan and replacing both seals (Oil pan seal usually needs replacing when you pull the timing cover). I also replaced the pump at this time, since its a pita to do anyway, might as well get it done.
CB Channel 17
Space Ghost
'1992 Dodge W-250 Club Cab Long Bed V8 5.9l 4spd H.D Auto 4x4 4.10 Gears
'1974 KIT 11' Kamper
'1987 Custom Built Pullman Mini Camper (The Pullman Mini Camper Project)
'2004 Bi-Mart 1000lbs Cargo Trailer (Chuck wagon)
