Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 02-23-2008, 09:40 PM
rnj rnj is offline
Send a message via MSN to rnj
How to tell if keyless entry was an option
Just acquired a 1997 88, pretty sweet, 74000 miles on it. No keyless remotes though. Did these come equipped with it, or can add the bcm??? next.... The back part of power seat, does not work. Relay/fuse, or motor, and last, is there a light on the cluster that indicates the cruise control is engaged? TKS!!!!!!
I forgot, it was driven up here from florida and my father in law added regular antifreeze cause it was low. he said he only added about 1/2-1 qrt of antifreeze to the system. should i have the coolant flushed????
Old 02-26-2008, 04:06 PM
rnj rnj is offline
Re: How to tell if keyless entry was an option
I guess it might be under glovey, will need to check to make sure.
Old 03-01-2008, 01:20 PM
raybo100 raybo100 is offline
for your antifreeze question:
Buy a tester to see how strong it is (recommend -40) only couple bucks at Canadian tire
I would just go ahead and change it if you are unsure if it has been changed before as it also has rust and corrosion inhibitors in it
Coming from Florida it may not be that strong of a solution as most people think it is only for freezing but it is also for boiling as well
(do a once over checking all fluid levels and changing is a cheap preventive medicine)
Ray
Old 03-04-2008, 10:40 PM
rnj rnj is offline
thanks for the reply! I will be having it flushed soon.
