Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 01-28-2008, 02:57 PM   #1
Bearwulf
Bearwulf's Avatar
'91 Lumina inj.?
I disconnect all inj. and have power one side & grnd. on other side of circuit. If I connect to just one inj. (doesn't matter which) I lose the grnd. & show power on both sides of cir. (both done with key in run pos.). Same happens with key in start pos.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Bearwulf is offline   Reply With Quote
Old 01-28-2008, 04:22 PM   #2
j cAT
Re: '91 Lumina inj.?
remember injectors are grounded by the pcm/ecm so make sure the computer grounds are good . do not screw with grounds with power to computer or you can damage it......
j cAT is offline   Reply With Quote
Old 01-28-2008, 06:09 PM   #3
Bearwulf
Bearwulf's Avatar
All changes of connections done w/key off. Can't figure why have no grnd. w/system connected. Test light does not flash when cranking with wires connected.
97-Lumina LS
