Old 12-12-2002, 12:44 PM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Angry Power loss after adding a K&N 57i Induction kit!!!
Hi Guys
I recently added a 57i kit to my 1.6 16v dohc non-vtec and since doing so i have lost power, the only other engine mod is a janspeed rear silencer. I think it is getting too much air, I have been told by another forum that if i ran the car until its warm, turned it off, took out the fuse for the ECU, replaced it and then started it up and let it run for 60 seconds without touching the throttle it would re-set the ECU accordingly, I wasn't sure that it would work so I went to my nearest Honda garage (about 20metres from work) and they said that the ecu will not reprogram itself and the only adjustment you can do is the idle speed and not the mixture or anything else....
Anybody got any thoughts on it or any ideas how I can sort it out??
Cheerz
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 12-12-2002, 01:11 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
Iv never heard of getting too much air and causing problems...I know of some idiots that like to take out their air filter all together when racing...dont ask...i dont know...but the point is they dont have a problem. The only thing I can think of is the silencer is causing too much restriction. If you can i would remove it and see what happens
Old 12-12-2002, 01:21 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yes air can cause a problem, with all the extra air your car is now getting, your not getting enough fuel into the chamber to mix correctly with the added air. buy yourself an adjustable fuel regulator and i assure you your problem will be fixed.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 12-12-2002, 01:25 PM
plkelley's Avatar
I didnt think an engine could pull more air than it could use without some type of forced induction. huh...thats definetly something to consider when purchasing an intake system. good post crxlvr
Old 12-12-2002, 01:28 PM
plkelley's Avatar
Do you have to get an adjustable fuel regulator, or could just get a high flow fuel rail and larger injectors.
Old 12-12-2002, 02:51 PM
91zc 91zc is offline
There is no need for larger injectors with just bolt ons. You should just get the fpr and turn the pressure up a bit. That should compensate for the mild mods you have.
91 civic 4dr
b16a
14.8@94
Old 12-12-2002, 03:07 PM
Skeme1's Avatar
Skeme1 Skeme1 is offline
civic 16valver - whats up with the word "Cheers"?
i know a few people that say that too. is it just a replacement for "thanks"?
just curious
Old 12-12-2002, 03:14 PM
EFsleeper's Avatar
EFsleeper EFsleeper is offline
Send a message via AIM to EFsleeper
just curious
Damn canadiens! Cheers is what english people use for goodbye, thanks, several others sayings...
Stop looking at my Autometer!
Old 12-12-2002, 04:39 PM
MKS MKS is offline
hay dont K&N garantee a performance increase with those kits ????
1989 Toyota Supra 3.0i Turbo
150mph I think I'm nuts
Custom S/S Exhaust 5" Tailpipe
K&N Induction kit
Bailys Piston Dump Valve (WOOSH)
Wategate Shimmed by 5mm ummm boost
Old 12-12-2002, 06:42 PM
D16A6 D16A6 is offline
You do not need an adjustable FPR for the k&n air filter you put on. And the ppl that take their filters off when racing are not idiots, they simply want more air, which is what a Honda needs for speed and Hondas respond alot better to this than alot of other cars. Your problem would have to be the silencer, unless you didn't mess something up installing either of these two mods.
Old 12-12-2002, 08:04 PM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
Originally posted by D16A6
You do not need an adjustable FPR for the k&n air filter you put on. .
Is the induction kit actually just a filter? Im pretty sure it isnt
Old 12-18-2002, 10:05 AM
Civic Jim's Avatar
Thanks
I might just try to reset the ecu that somebody has told me about but I want to know how to do it in a lot of detail becuase i dont want to knacker it up coz i use this car for work so if anyone else has done it I would appreciate a step by step guidehow to do it.
Cheerz
B16A1 I/H/E
4TH GEN UK SITE
Old 12-19-2002, 12:55 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Cheers is British/Aussie for "bye" or thank-you (Aussie: "Cheers mate")
If the K&N is sucking in hot air from the engine bay, then yeah, you'll be losing power.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 12-19-2002, 05:59 AM
cyberrexer's Avatar
cyberrexer cyberrexer is offline
Send a message via AIM to cyberrexer
Re: Thanks
Cheerz
The ECU is such that it will reset itself eventually, but if you want to help it along, resetting will do this straight away. Like you’ve already said the car needs to be warmed up first.
Step 1. Warm up car
Step 2. Turn engine off and pull the hazard fuse ~ 10A (this is for the siR, probably the same for your car, mine is located in the fuse box under the hood/bonnet).
Step 3. Wait 15-20 sec’s and put the fuse back in.
Step 4. Turn engine on and let it idle for 10-15min. DO NOT touch the gas/accelerator pedal!
Step 5. Turn engine off.
Step 6. You’re good to GO!
This will allow the ECU to learn the new settings, i.e. how much air is coming in to the chamber, thus altering the amount of fuel accordingly.
However, as Setanta already said, the K&N have a very poor design, most of the induction kits for the CRX’s/Civics bolt straight onto the throttle body, which is the last place you want it as it’s fairly hot their! You will loose power sucking in warm air. If this is the case, you need to get a induction pipe that positions the cone filter near the battery and add a cold air feed from the front of the bumper.
Aftermarket induction’s will loose you low down power and increase top end power, so take that into consideration. How do you know it’s actually loosing you power? Just feeling it is probably not the most scientific way, put it on the rollers with both setup or a cheaper option is to take it on the track (but this is less accurate).
Also as someone has already mentioned it could be your restrictive silencer.
Cheers
1991 CRX siR
1991 CR-X Si
1993 UK 2.2 4WS - FOR SALE
2005 Lexus IS200 - SOLD
1990 MX-5
Old 12-19-2002, 06:12 AM
Civic Jim's Avatar
Talking Thanks
Thanks very much thats the info I needed
Speak to ya again
Cheerz
B16A1 I/H/E
4TH GEN UK SITE
