Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 11-26-2007, 04:32 PM
Stick462 Stick462 is offline
Angry 2004 p71Charge/nocharge alternator problem
I have just bought my 4th crown vic /second p71 2004 last week .PROBLEM is this charge/ no charge problem with the alternator.My lights go bright then dim /car over charges then dis charges.checked all connections to battery and alternator .I have tryed 4 different alternators same problem.power at alternator post 14.5 but at battery no power or 13.2 volts. HELP PLZ
Old 11-26-2007, 05:36 PM
1996Chreokee 1996Chreokee is offline
Re: 2004 p71Charge/nocharge alternator problem
wiring issue... when your checking the voltage at the battery gently wiggle the wire harness under the front passenger side bumper cover... I use the word gentle (strongly) They have issues with the wires corrording in that area... make sure you don't have any wires grounding out... Please respond bac k with your results as it helps others with similar problems
Old 11-30-2007, 06:53 PM
Well people it was the green wire that comes from the voltage regulator/ alternator back to the computer .couldnt find the fault in the wire so i just replaced it.Works like a charm.
