Go Back   Automotive Forums Car Chat > Geo > Nova | Prizm | Spectrum | Sprint
Old 10-11-2007, 03:10 PM
mrfixit098 mrfixit098 is offline
94 prizm airbag
I replaced the multi turn and wiper switch on my 94 prizm. I got in a hurry and turned the switch on before plugging the airbag backup now I dont know how to reset the airbag light.
Old 10-27-2007, 11:59 PM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Re: 94 prizm airbag
Your vehicle uses a Toyota system. You can clear the code and reset the airbag light this way. Using the datalink connector, locate terminals TC & AB
  1. Connect two test leads to terminals "TC" and "AB" of the DLC. NOTE: Make sure that the test leads have sufficient length to reach into the passenger compartment. If the leads are too short, you will not be able to watch the air bag indicator and, consequently, not know if the DTCs were cleared.
  2. Route the test leads into the passenger compartment.
  3. Turn the ignition switch to "ACC" or "ON" and wait at least six seconds.
  4. Ground the test lead connected to terminal "TC" for one second.
  5. Remove the "TC" test lead from ground and IMMEDIATELY ground the test lead connected to terminal "AB" for one second.
  6. Repeat this procedure two more times.
  7. Continuously ground the "TC" test lead until the air bag indicator flashes rapidly (50 millisecond cycles). If the air bag indicator remains illuminated, then repeat Steps 4, 5 and 6.
  8. Turn the ignition switch to "LOCK."
  9. Disconnect the test leads from the DLC.
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
