Old 08-21-2007, 08:21 AM
Meridivs's Avatar
Meridivs Meridivs is offline
Question Automatic transmission "clutch" noise
I have a 1992 Chevrolet Lumina APV (3.1 engine) with the following problem:
Sometime, usually after the engine is at operationg temperature, I hear a loud "bang" like two clutched hitting each other hard everytime I switch into Drive from Reverse or Parking.
Otherwise the transmission works and shifts very smoothly but that noise really started to bother me.
Does anybody know what makes that noise and what it means?
Old 08-21-2007, 11:16 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Automatic transmission "clutch" noise
Since it only happens when you change direction/load, I'd say its a sloppy CV axle joint. Rear wheel drive/4-wheel drive vehicles experience a similar situation when the drive shaft u-joints go bad, they will clunk or ping when going from reverse to drive to park etc...
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-21-2007, 01:12 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
I guess you looked at the engine roll restrictors on top?
You'd usually feel the motor slamming around on upshifts too if they are broke, though..
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 08-22-2007, 05:54 AM
Meridivs's Avatar
Unhappy Re: Automatic transmission "clutch" noise
I'm pretty sure it's coming from the transmission housing (I'll check again this evening to be sure) and it only happens when I switch from Parking or Reverse into Drive with a hot engine.
On cold the switch goes smooth as silk with no audible noise whatsoever. That's why this loud "bang" when going into Drive after the engine has warmed up worries me.
Old 08-22-2007, 08:30 AM
Perhaps the beginning of a torque convertor lockup that's dragging when warmed up....does it seem like the engagement hits unusually hard when you hear the sound?
...empty gun rack.
