| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
Any Ideas on how to get the code to unlock the radio? I do not have an owners manual and the last time this happened I went to a dealership and paid 40 to have it reset.
I am trying to save my money this time. I called the dealership and they said I would have to pay again to reset the radio. Thanks |
#2 | |
Lactose the Intolerant
![]() Join Date: Aug 2004
Re: 97 Lumina Radio Locked
I used to have a way to do it...but the dealer code I used has been changed...
It's an involved process, you have to call in to the 800 number, enter a dealer code, it tells you to push certain buttons on the unit in sequence, which in turn causes some identifying numbers to be displayed on the unit, you enter those numbers into the phone keypad, and the system gives you a final unlock code sequence to enter...they've got it all figured out so you are helpless without a dealer code...takes all of five minutes to do it, good money maker for them. I know I've seen the procedure on here with other dealer codes, use the search function for "radio unlock code" or whatever in the GM forums and you'll probably find one that works...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
#3 | |
I seen on another website where it says to hold in the hour button the hold in the minute button to the numbers. Did you ever hear of that by any chance.
I am just a little upset that the same dealer I used a couple years ago and told me that they will keep the code for me and reprogram at no charge is now wanting to charge me.... |
#4 | |
Yeah there is a shortcut if you already have the code, but in your case, it's a two step process, the system you call into is to recall the code.
If you have the code, you can just put it in the mode to accept it (what you are talking about), enter the numbers when prompted by the display, and it's set. But that won't help you in this case. Did you look in your manual and see if they might have written it in the back or anything? That's where I wrote mine down as I was doing it.
#5 | |
I did the search as you suggested and I found the steps to unlock it (getting the numbers, calling and then getting the code) and it worked....runaround
I printed them and will keep them in a safe place. It took me maybe 5 minutes. Thanks again |
#6 | |
Wow, my memory of how it works is a little mixed up, I just looked at it again...it's been about 5 years since I used the procedure...but glad you got it working.
#7 | ||
Corndog... |
#8 | ||
#9 | ||
![]() Join Date: May 2007
#10 | ||
Corndog... |
