Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-19-2007, 07:24 AM
JoeTex JoeTex is offline
Loose Shifter On A 2000 Cvpi
I HAVE A KINDA LOOSE SHIFTER ON MY 2,000 CORWN VIC P.I. AND I WAS WONDERING WHAT I COULD DO TO GET IT FIXED OR IF I NEED TO TAKE OFF THE STERRING WHEEEL OFF IN ORDER TO GET TO IT OR DO I JUST NEED TO REMOVER THE STERRING COLUM PLASTIC COVERS TO GET TO IT ANY ADVICE WOULD BE HELPFULL...TRYING TO SAVE UP ON...THNX YU'ALL
Old 05-21-2007, 07:07 PM
fleettech fleettech is offline
Re: Loose Shifter On A 2000 Cvpi
you either have worn out bushings in the steering coloum or it is very likely the 2 or 3 screws that arm on have loosened up both are easy fixes
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 05-23-2007, 05:24 AM
Hey Thanx Partner..i'll Take A Peek At That.cause Its Really Wearing Out The More I Shift.but One Other Question I Tried Getting At It But I Was Kinda Lost On The Procedure..i Need To Take The Dash Apart To Get To The Sterring Colum Right??
Old 05-23-2007, 06:59 PM
you dont have to pull the whole dah apart there are a couple of ways to change the bushings1 unhook the battery and let it sit for a while then remove knee bolster and unhook everything that plugs into the coloum remember to unhook the trans indicator so you dont break it and pop the shift cable off then pull the whole coloum out and put it on the bench or floor. remove the shift interlock solonoid and caps off the shift tube. remove then install new bushings. I usually put a little white grease on and in them. reinstall everything. or you may get lucky to just drop the coloum down enough to get caps off and install new bushings. it sounds a lot harder than it really is.
Old 05-24-2007, 09:30 AM
Yeap Iagree It Does Sound Comlicated..you Left Me Puzzeled For A Minute There...but I Think I Can Manage It..thnx
