Old 05-18-2007, 11:59 AM
Hunter31060411 Hunter31060411 is offline
Question 2004 Cavalier Check Engine Problems
I have had a plroblem with my check engine light comming on for quite some time now .
I've been getting DTC P0455 Evaporative Emissions Control LEak (Large) and can't seem to find the problem. I've changed the gas cap a few times and haven't noticed any fuel odors around my car.
Just recently I also got DTC P0480 Cooling fan 1 control circuit malfunction.
I have no idea what to do for either of these problems. Any advice anyone could give would be greatly appreciated.
Thanks
Old 05-25-2007, 10:51 PM
2003black2coupe 2003black2coupe is offline
Re: 2004 Cavalier Check Engine Problems
Thanks
VENT VALVE!!!!!!!!!! Just had it done....
Losin' aint an option, my destination is the top of the world
Old 06-08-2007, 05:40 PM
beautiful_eyes beautiful_eyes is offline
a 2004 cav? wow! anyhow all these cavs have these "emission" problems. mine is 0440, 0445 and some other shit....could be my vent valve or the filler in the tank, maybe i should try the gas cap.
Old 06-08-2007, 08:05 PM
I would get them to check the vent valve first...And make sure that your gas cap is on really tight! Thats what my problem was!
Old 06-08-2007, 09:57 PM
ya, my cap is loose...vent valve? hmm.
Old 06-09-2007, 08:09 PM
Yepperz, have it checked...also.....Positive Battery terminal and fuel filter!!!! I have been running supreme fuel in it and it has been fine!
Old 06-10-2007, 02:01 AM
ok thanks.
Old 06-10-2007, 08:39 PM
Your Welcome....Let me know if it helps!!!
Old 10-03-2010, 08:51 AM
loachdvr loachdvr is offline
I corrected the P0455 code on my 04 Cav by replacing the "Canister Purge Solenoid". (located on rear right side by gas tank. You'll see a hose running from the 'cannister' to the solenoid.)
(Part number PV155 from AutoZone) I think Napa has them also.
I have seen other reports that have found the 2 wire harness that connects to this Solenoid to be bad , but mine was fine, so I replaced the Solenoid itself, and the code has not returned.
