Header gaskets question
Will be replacing the Hookers on my 1989 350 V8 in 3 or 4 weeks. Was given a kit including header gaskets and bolts but I'm sure that they are just run-of-the-mill stuff.
What would be a good header gasket to use and what about the bolts? Copper or Aluminum any good? Anyone with long experience of this? Also, what about the collector gaskets. Are copper ones worthwhile? The rest of the exhaust is coming from Summit. When joining up the pieces should some kind of sealant be used? I appreciate any and all replies. Thanks, David
Bought my first truck - made sure it was American |
Re: Header gaskets question
I've used the copper gaskets with good results. Even taken the headers off and put them back on with the same gaskets and never had any leaks. To me it's worth the money for header and collector gaskets.
1989 Camaro RS convertible ![]() Engine & trans has been changed to 350 TPI w/ 6-speed manual K&N filter BBK 58mm Throttle Body Richmond 3.73 gears Spohn full length adj. torque arm Spohn lower control arms w/ poly bushings Spohn Adj. panhard bar w/ poly bushings Spohn front & rear sway bars Spohn weld-in subframe connectors PST complete front end rebuild kit KYB struts & shocks |
rob67. Thanks for the info.
