Old 04-16-2007, 08:48 AM
scottynpt scottynpt is offline
2000 jimmy wont start after heavy rain
Heres the newest old problem....
My Friggin truck does not want to start after it rains a lot.
What do you guys think? New coil packs right?
Anyone know what the average price is for that part and about how many hours on the install?
Thanks,
your pal,
Scott
Old 04-16-2007, 11:38 AM
maxwedge maxwedge is offline
A990 racer
Re: 2000 jimmy wont start after heavy rain
Had issues with the coil wire on that truck, is it COP or does it have one coil, if so replace all the wires.
Old 04-16-2007, 12:02 PM
to be honest, I am very unfamiliar with this part of the motor.
I always thought the coils were just what my truck had insted of a regular distributor.
are you taliking about the plug wires?
Old 04-16-2007, 01:37 PM
A990 racer
Do you see a distrubutor and plug wires from it?
Old 04-17-2007, 09:41 AM
yes.
the coils are inside right?
I heard they can get corroded and if you clean them with a wire brush it helps.
Old 04-18-2007, 07:43 AM
muddog321 muddog321 is offline
AF -Advisor
Which motor - if a 4.3 it has 1 coil on pass side with the Ign mod and heat sink attached. Classic no wet start is dirty cap/rotor.
Old 04-18-2007, 08:56 AM
Yeah. It's a 4.3. (good motor)
Is that all I need to replace. U think the coil isnt the problem. That sounds a lot easier than I previously assumed.
So, you are saying try replacing the cap/ rotor first and see how it goes.
-Scott
Old 04-18-2007, 09:13 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
I would say it needs a tune -up which includes the cap/.rotor plugs/wires, depending of course when atune up was done on it.
Old 04-19-2007, 10:52 AM
duke350 duke350 is offline
A can of WD-40 or any other moisture displacement spray can help you track down the problem. Just spray electrical parts one at a time until the problem goes away after a heavy rain. You also may be able to pop the hood at night or in a dim/dark area and see spark jumping. This will especially help if a full tune up doesn't fix the problem.
Old 04-19-2007, 01:41 PM
wow! thatks guys. you are life savers.
