Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 03-29-2007, 06:26 PM   #1
1992eclipseGS
Installing side mirror with lights/ quick question.
I'm installing a set of side view mirrors with lights on them.... My question is:: Where should i tap them to so they'll only blink on when i'm turning?? I can't do the side markers on the front bumper because there set to stay on with the headlights. Someone told me to tap them into the fuse box, but i'm curious to how one side will blink but not the other if both mirrors are using the same electrical source. My only other option is to use the turning blinkers on the headlights.. if thats the case, is there anywhere that i can locate that source with out actually having to run a wire from my side view mirrors to my headlights?? Oh and i don't have my owners manual, so if someone knows exactly which fuse is for the right and left turning signals.. that would be helpful.. thanks.
1998 RS
5 speed, Stock front bumper w/molded urethane lip, Blitz side skirts, Bomex rear, JSP Carbon Fiber hood. Halo Projection Headlights, Escort radar detector, Turbo style spoiler, 1,200 watt sound system with 2 dual 12 subs, 20% executive tint, 17" sport rims, Custom built 2 1/2 Exhaust, OBX 4-1 Header, CAI, KYB GR-2 struts, Sprint lowering springs.
1992eclipseGS is offline   Reply With Quote
Old 03-29-2007, 06:30 PM   #2
SilvrEclipse
Holset powered 420a
SilvrEclipse's Avatar
Send a message via AIM to SilvrEclipse
Re: Installing side mirror with lights/ quick question.
I think it would be best to tap into the wiring harness that goes to the headlights.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
SilvrEclipse is offline   Reply With Quote
Old 03-29-2007, 06:38 PM   #3
1992eclipseGS
Yep.. thats my plan as of right now. Is there anywhere I can locate the set of wires inside the car.
1998 RS
Old 03-29-2007, 06:52 PM   #4
SilvrEclipse
Holset powered 420a
I think that my there is some kind of control unit for the blinkers thats inside the car. I can hear it clicking when the blinkers are on and its located right behind the cd player. Im not sure if you could tap into that but you could look into it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-29-2007, 08:46 PM   #5
david-b
Dave is THAT guy
david-b's Avatar
That sound is actually the relay. You should be able to tap that. I believe its actually behind the instrument panel. Have to go in from the bottom IIRC. Just turn them on and listen to for it.
You may (and I'm just guessing here), be able to tap off the steering column.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
david-b is offline   Reply With Quote
Old 03-30-2007, 09:51 PM   #6
1992eclipseGS
Thanks for the replies.. My trunk interior is out of my car right now. So I might has well just run the wires to the rear turning light, Which I do believe is the middle light. Thats probably my best route to take. I don't wanna deal with the dash and the intrumental panel if i can avoid it.
1998 RS
