Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-05-2002, 05:45 PM
CrazyFukr CrazyFukr is offline
Banned
Send a message via ICQ to CrazyFukr
My Integra grinds going into 3rd gear, suggestions?
I just got a 1991 Acura Integra GS with 5-speed manual about a month ago, and like the 2nd day I had it I started hearing grinding noises going into 3rd gear. It ALWAYS grinds going from 2nd to 3rd, unless the car hasn't been turned on for like 8 hours or more, and it some of the time grinds going from neutral to 3rd. Is my transmission going to just like blow up one of these days or should I even worry about it?
Old 10-05-2002, 06:23 PM
TatII TatII is offline
your syncro from 2nd to 3rd is bad. time to change the syncros.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 10-05-2002, 09:25 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
3rd is overrated
3rd gear is over rated.. only slows you down.
just skip it, 2nd to 4th... remember the fastest way to accelerate is to travel though the gears faster... so why not skip a useless gear?
I say, Dont worry about it!
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 10-05-2002, 10:57 PM
hmmmmmm red neck i hope your not serious hahahha casue as weird and as bogus as that sounds, it does sorta make sense too. i know people who skip second but not third, but thats a whole different story.
94 Acura NSX
Best E.T. 13.559
Old 10-05-2002, 11:15 PM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
No chance Redneck, he's got an acura, he doesn't have enough torque to skip gears...
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 10-05-2002, 11:43 PM
-The Stig-'s Avatar
On Fire!
haha yes i was joking... i had no real valuable information to give so i gave something totally opposite from you Tat.
Old 10-06-2002, 12:27 AM
Banned
"your syncro from 2nd to 3rd is bad. time to change the syncros."
yea a friend of mine said something about syncro's...
is that expensive/hard to change/replace the synchros?
Old 10-06-2002, 01:57 PM
Tegon-gsr Tegon-gsr is offline
Try mtf fluid first and if that's not it sorry its your sincros
Old 10-06-2002, 02:13 PM
Banned
where do you buy mtf fluid and how do you put it in
i heard that you have to lift it up on a rack for manual transmissions
Old 10-07-2002, 10:47 AM
Blk94Tegi Blk94Tegi is offline
trany
I have a 94 RS Integra with a manual and I grind on 2nd and 3rd : \ I've made sure I'm not the problem , each time the clutch was to the floor, ugh better be a cheap fix but I'm thinking its the syncro thingie too heh
Old 10-09-2002, 04:53 PM
Cyprus106 Cyprus106 is offline
Send a message via AIM to Cyprus106
yea, make sure your not the problem. I used to push and release the clutch too fast and grind a lot, so I bought a short shifter and it's been fine ever since. lol, I figured the quicker I shifted, the less likely I'd be to lay off the clutch too early. It worked tho.
One question I had: I think it's just Hondas, but getting into reverse is the biggest bitch. I'll get in the car in the morning, put it into reverse and start going and it'll grind. Sometimes it wont go in reverse. I have to put it in 1st then reverse. Sometimes I'll put it in reverse but I know it's not all the way in so when I push the gas I have to hold it for just a second until I start moving and then it pops. but If I don't, It'll just grind away. On occasion it'll grind when I hold it and make it worse.
I thought maybe the reason it wouldn't go into reverse is the safety thing. If you're in like 3rd you cant put it into reverse. You have to go to 1st gear first.
I talked to a friend about it and he said his Integra does it too and that it was just a honda thing.
The warranty runs out soon, should I take it in?
Hung by a halo or stabbed by horns, sad to say; they're both the same
Old 10-09-2002, 05:30 PM
tranny
I wouldn't take it into the shop after hearing the exact same thing from everyone else. As for my car I dunno what to do cause Ill have the clutch in all the way and grind either 2nd or 3rd so i dunno what to do.
Car wont go into 3rd gear please help jahfhernandez Crown Victoria 1 07-10-2010 12:54 PM
O2 passport grinds going into high gear gbic1 Rodeo | Passport | MU 3 03-16-2010 11:18 AM
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
89 probe won't shift into 3rd gear BlueBilly777 Probe 1 03-24-2005 05:22 PM
my civic grinds going into 3rd lsj '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-19-2004 12:54 AM
