92 Grand Caravan
Whenever i make a turn i hear a clunk which comes from the back of van. Shocks are new. I had Leaf spring Boosters installed about 8 years ago and the bolt which sticks up looks like it is digging into the shocks a little. Could this be the noise i am hearing on turns if so how can i stop the noise?
I have another issue for the last six months when i turn my turn signal on and make a turn the signal dosn't turn off when i turn the wheel i have to shut it off manually. what could this be and how can i fix it? |
Re: 92 Grand Caravan
Cut or grind the bolt down or replace with shorter bolts.
Replace the turn signal lever or live with it.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
is that really the only noise it could be? I see the indentations in the shock so i am assuming it is is there anything else i should look at i know it is not the exhaust?
Is it hard to replace the turn signal lever can you briefly tell me how to go about that? |
Your bolt issue seams the most obvious place to start. Also look at fuel tank mount straps, parking brake cable, exhaust, wheel well liners, back seat mounts, spare tire mounting, wheel jack stowage.
http://www.autozone.com/servlet/UiBr...3d8010cbdf.jsp Scroll to the bottom. Click on diagrams to blow them up. This appears to be fairly scant info. I would buy a manual.
