Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 11-17-2006, 08:44 PM
bo'03Monte bo'03Monte is offline
Send a message via AIM to bo'03Monte Send a message via MSN to bo'03Monte
OIL 03 Monte Carlo
My low engine oil light came on a few days ago and I took it to have an oil change today. They called me to the shop and showed me that my dipstick was not even registering that my car had any oil in it. Normally when I get an oil change its been at least 1 qrt low on oil because I drive so much. I have 104,000 miles on it and I didnt think anything of the light because it's normally low but that light has never came on before. I really would like to know how many quarts of oil a 2003 3.4 V6 Engine holds. The paper said they put 4.6 Qrts into my engine today. I was under the impression that my car takes 5-6 Qrts of oil. Someone please help me. I cant afford for my car to blow up right now..lol...
Thanks
Old 11-17-2006, 11:52 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: OIL 03 Monte Carlo
Well.. according to my owner's manual.. a 3.4 takes 4 quarts
Maybe you got an oil leak?
Old 11-18-2006, 08:59 AM
maxwedge maxwedge is online now
A990 racer
Thumbs down Re: OIL 03 Monte Carlo
Thanks
Let me get this straight you drive with the lite on, the oil is normally low and it seems like you never check it until there is no oil!! It holds 4.5 qts with a filter. Good Luck!!
Old 11-18-2006, 10:07 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Thanks
They still make dip sticks to tell you if it is low or full on oil.
If you want your engine to live very long.
Find someone to show you the proper way to use it.
Check it after a oil change to make sure they filled it up.
It is best to check the oil when you refuel.
If the oil level is going down check it every morning before you start the engine.
And if the oil light comes on while driving you had better find a spot to pull over and use the dip stick to check that oil level.
If the oil level is going down add to it is full and start looking for a oil leak.
Unless your car is smoking out the tail pipe it may have a oil leak.
If so get it repaired before you burn up the engine.
Also look under the car after it has been parked for a oil spot.
MT
Old 11-18-2006, 03:09 PM
Thank you all so much for you response. I know to check my oil level. I guess I just wasnt paying that much attention. I know better now. I was just wondering if they were putting the right amount in. I was thinking it held 6 qrts. Thanks again! You guys are great!
