Go Back   Automotive Forums Car Chat > Other Cars
Old 10-05-2006, 05:26 PM
stockcarpete stockcarpete is offline
getting spark to a 3 cyl w/no brain
im trying to make a 3 cyl engine run with out using the brain ???? its a 93 geo 3 cyl that now has a carburator on the intake side and no trany its in a hydroplane boat hooked up direct to shaft from flywheel side it turns over fine just need to figure out spark mess it has a distributor and coil from car there are 2 wires from dist and two wires from coil which goes where do i need to use a module from a regular distributor and wire in a MSD box ???? CONTACT PETE ATE-MAIL OR CALL ME THANKS (716)861-7506
Old 10-05-2006, 06:13 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: getting spark to a 3 cyl w/no brain
MSD is my first thought. Have you contacted them or posted to their forum? you should be able to set up a crank trigger. They would know the options.
http://www.msdignition.com/1support.htm
