Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 08-21-2006, 07:32 PM   #1
Rub_Dr
89 S-10 died and won't start
Hi, hope someone can help. 89 S-10 2.5 5 speed...Kid was driving home and he said truck lost power and died. We got it home and started investigating...... found a broken wire in the distributor and a fried control mod. Got that taken care of and had spark again but no fuel now (grrrrrrrrrr) replaced the fuel pump switch and now fuel pump is working, but still wont start. Its like the throttle body is dead, the IAC will cycle when you have the code reader plugged in but wont when its not and now getting a code 43. Tried a spare Map sensor that i knew was good and still got code. Any ideas or suggestions? Im tired of scratching my head on this thing.
Rub_Dr is offline   Reply With Quote
Old 08-22-2006, 11:46 PM   #2
jackass#1
jackass#1's Avatar
Send a message via Yahoo to jackass#1
Re: 89 S-10 died and won't start
after swaping out map did you undo the neg to battery for awhile(to reset computer)? if not you will get that code until reset. you have spark and fuel but no start? check for good strong spark(weak will not do). check fuel pressure,too weak wont do. if all is still good,check timming. is fuel comming out of injectors?
jackass#1 is offline   Reply With Quote
Old 08-23-2006, 02:10 PM   #3
Rub_Dr
cleared the code, rechecked timing, spark and fuel.... all good. no fuel sprays from injector and iac is dead, but like i said in earlier post.... if ya plug in the code reader it cycles and works. got to be electrical but im not sure what wires go where or what all is in line on those circuits.
Old 08-23-2006, 10:18 PM   #4
joshmitch05
Injector plugged in all the way? Sounds like something is wrong there.
joshmitch05 is offline   Reply With Quote
Old 08-24-2006, 08:33 PM   #5
Rub_Dr
Lightbulb Re: 89 S-10 died and won't start
double checked injector its fine, has constant 12 volts and no pulse so did more surfing on the net this afternoon and found that hall effect switch is supposed to trigger the pulse, so will check that deeper on monday when have time, and will keep posted what i find.
Old 08-27-2006, 02:05 PM   #6
tom3
Fuel or spark. Get a can of starting fluid. Take the top off the air cleaner and spray some of the fluid in while someone tries to start it, keep head back in case it backfires. If it starts and runs on the start fluid it's a fuel problem. If not it's ignition related. If the clutch is bad the engine will run, but slip when trying to go. Worse slippage in 4th or 5th gear than first, and usually it will be hard to shift.
tom3 is offline   Reply With Quote
Old 08-31-2006, 11:51 PM   #7
Rub_Dr
quick update, Problem solved.... brand new distributor with a bad hall effect switch, autozone swapped it out and truck is up and running now.
