Old 05-06-2006, 09:57 AM
zander5 zander5 is offline
96 G voyager Ball joint replacement
I need to replace the ball joints on my 96 G voyager, do the ball joints need to be pressed out by a machine shop, or can I rent a tool to doo this and has anyone replaced them what are the best tips.
Thanks
zander5
Old 05-06-2006, 01:20 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 96 G voyager Ball joint replacement
The good book says to take the control arm to a shop and have the BJs pressed out and in.
Old 05-08-2006, 11:06 AM
doratheexplorer's Avatar
doratheexplorer doratheexplorer is offline
Originally Posted by zander5
Do the ball joints need to be pressed out by a machine shop, or can I rent a tool to do this?
'95 Voyager: at 100K miles, I was able to press out using a 3 in 1 ball joint press. Luckily, the joint wasn't spot welded. I also needed a prybar to hold the control arm down and a pickle fork to separate the steering knuckle from the the control arm. You will need a good night sleep, a bowl of Wheaties, and two good arms and two good legs to get it done. A larger helper is a plus .
