| Latest | 0 Rplys |
| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
Show Printable Version | Email this Page |
#1 | |
98 cavalier RS running rough lost power, MPG
my car runs hot... due to plugged radiator. it runs at 190-230 until 60 mph then cools down to 140. it started running a little rough the other day and i noticed my gas guage was going down faster than normal. after work i opened the hood and looked around the plugs.... it was about 11 30 pm and i noticed all 4 wires arced. i figured the heat melted the wires a little so i taped up the wires from end to end ... checked them and no more arc... my mpg picked up a tad but it still has a noticeable power loss under heavy acceleration. used to kickdown into passing gear at 1/2 throttle... now it only kicks down when pedal is at the floor. any suggestions? please help! it has champion double plat plugs gapped to 0.60
#2 | |
Banned
![]() Join Date: Jun 2005
Re: 98 cavalier RS running rough lost power, MPG
Did you replace your plugs as well? First off get that collant problem fixed, that will help alot, then replace the plugs and then see from there.
#3 | |
the plugs are only a month old im getting the new radiator and wires this week. ill post the results
#4 | ||
Hope it works out, it the rad obviously got so hot and it heated the whole system and it ended up melting the wires like you said and probably damaging the spark plugs which is why the MPG was a bummer. Swap it all and hope for the best.
![]() The New Ride!! 2002 Cavalier Coupe.. ![]() Quote:
#5 | |
mpg up and much missed power is back
and im getting the radiator tomorrowp.s. gap in number 2 plug was off by .004 from the other 3... it was .064 instead of .060 |
#6 | |
so improperly gapped plugs was your problem????
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM, 1981 Fairmont 6cyl 3 speed 1978 Ford Ranchero GT 302 with a few goodies |
#7 | |
Banned
he replaced the wires as well if I remember right
#8 | |
it was moreso the wires but the plug may have helped it
#9 | |
oh alright
