Old 07-03-2002, 12:42 PM
markpa's Avatar
markpa markpa is offline
Big Problem Please Help
Just like the subject line says i have a big problem with my car, on the way back from work the car just started to loose power and just turned off. I tried starting it up and it started but the engine started to shake like crazy, and when i opened the hood there was a skweeekinbg sound comming from around the timing belt. My guess my timimg belt has come of or completely snapped,,,,,If anyone has any suggestions please respond. Thanks
Old 07-03-2002, 02:00 PM
higgimonster's Avatar
higgimonster higgimonster is offline
I would definetly not turn the car back on until you know what the issue is. take your valve cover off and take a peak inside. you will know instantly if the belt is to blame. good luck.
Old 07-03-2002, 02:15 PM
markpa's Avatar
Thanks, I took the vavle cover off including the belt cover and its fine, so its gotta be something else. prob my valves???
Old 07-03-2002, 04:39 PM
b16a3sol b16a3sol is offline
sounds to me like you lost one of your cylinders due to something. it could be something as simple as your spark plug has failed, or something all the way to your injectors or something more serious crapped out. check for spark in all your cylinders, make sure your fuel pressure in within spec, then try compression test. see if anything there turns up something.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 07-03-2002, 07:10 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
if ur timing belt snapped, then your engine would have been gone, so i doubt it was that to blame.
id also say check your plugs, injectors.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-05-2002, 05:42 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Sounds that way to me also. Did you do anything to the engine before you went for that drive? Decreasing engine bay?
That's not true, some engine has clearance for the valves in case of timing belt snap. The worst is to change new valves into the engine which require a lot of labor, but much cheaper than a new engine. But if your timing belt is snapped you shouldn't able to start the motor at all.
No offense Crxlvr, but I have seen the responds that I happen to see you posted up, and they all seems to be a bit exaggerate.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 07-05-2002, 09:50 PM
crxlvr's Avatar
none taken, but if a timing belt snaps while engine is revving, the sudden halt would cause the valves to hit into the piston after the cam stops spinning, while the velocity of the belt is on its way to damaging other parts of your car.
a timing belt snapping is the worst thing that can happen to an engine, and when it does 99% of the time, the engine is gone.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-05-2002, 10:25 PM
markpa's Avatar
Thanks for the replys guys, but luckily it aint the timing belt, i did a couple tests and and the problem is the oil pump, it completely died, that would explain why the oil light was on for a while. ANyways when the pump stoped working the upper part of the engine was getting lubricated so their might be a bit more damage caused. Ill find out tomorrow when i change the pump. But thank god it wasnt the timing belt.
