Old 02-10-2006, 09:10 AM
readyjoes readyjoes is offline
Lightbulb Howling noise
I have a 1996 blazer I have had this noise since I bought it 2 years ago I replaced the bearings and seals and brakes in the rear , put a new hub assembly on the right front , rotated tires it still sounds like its coming from the right front and it as I slow down and get ready to stop it it gets kind of a whining sound . never did anything with front brakes always thought it was more seroius then that does bad roaters and pads make noise . I would appreciate some opinoins Thanks
Old 02-10-2006, 01:30 PM
Re: Howling noise, please help
no coments come on please
Old 02-10-2006, 01:36 PM
jkdon jkdon is offline
Re: Howling noise
Hey
i have a 97 had the same problem a couple or years ago. the front diff 4x4 actuator was not completely disengageing the front diff. I noticed it most when I would slow down. the actuator is located below the battery. I actually rerouted mine next to the battery so it is easier to service. tug on the cable a couple of times and work it back and forward. I ended up replaceing my actuator and the vacum lines a few months after the problem and it has been fine ever since.
hope that works
jkdon
Old 02-18-2006, 02:09 PM
Re: Howling noise,still
well, I put a new Vacuum switch on and a new actuator, still have the noise , i notice when I test drove it I made a hard left circle it was smooth, when I made right hard circle it was really choppy Like it feels when you have the 4x4 on but it was off, going down the road straight and you put it into 4x4 its queiter and shut 4x4 off it gets louder right away Any Ideas, Thanks
Old 02-18-2006, 05:38 PM
billibong's Avatar
billibong billibong is offline
Re: Howling noise
Have you checked the front hub assembly?? Sounds like it could be bad bearing in the left front wheel, which means replacing the hub assembly.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 02-18-2006, 05:44 PM
Re: Howling noise
I have replaced the right front 1 year ago its sounds like its coming from the right ,but you think it could be the drivers side. Thanks again
Old 02-18-2006, 05:55 PM
billibong's Avatar
Re: Howling noise
When you turn to the right it puts all the weight on the left side, causing it to "howl". That is why I am suggesting it may be the left side.
bill
billibong
Repairs:
Old 02-19-2006, 08:05 PM
Paddle_Grl's Avatar
Paddle_Grl Paddle_Grl is offline
Send a message via Yahoo to Paddle_Grl
Re: Howling noise
I had a similar problem....check out this post from a few months ago...maybe it will help
http://www.automotiveforums.com/vbul...d.php?t=473777
thanks
Karin
Old 02-19-2006, 08:09 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
I experienced this too, it turned out to be a worn vacuum line. The line was rubbing against the front driveshaft!
Old 02-20-2006, 09:16 AM
Re: Howling noise
Thanks for the input, is there a good way to check the vacuum line on mind there is a plastic covering over it, I follwed it to the back of engine then lost it, I see the three hoses that come off the Vacuum switch but cant see were they go Thanks Bob.
Old 02-20-2006, 09:41 AM
herkyhawki herkyhawki is offline
Re: Howling noise
Check the front axle actuator cable. This connectes between the actuator and the axle. If it does not move freely, the spring inside the vacuum actuator is not able to release the front axle when you shift back to 2wd.
The cable is cheap and easy to replace.
Old 02-20-2006, 10:01 AM
Re: Howling noise
I am getting a little confused, so are you guys saying that is staying in 4x4 and not going back to 2w if I jack the front end up what should I check Thanks
Old 02-24-2006, 07:20 AM
Re: Howling noise
I jacked the front end up ,there really was no noise from the hubs, the the cv joints were solid ,I am going to jack it up again today , is there a way to see if the 4x4 is engaged or not ,also is there bearings on the diff, where the axle goes in looks like the seal is leaking bad on drivers side , could that be my problem , I don`t here any thing when its up ,is there a way to check that, I appreciate all your help, thanks
Old 02-24-2006, 04:44 PM
Re: Howling noise
I was trying to check the vacuum lines but have not found anything yet , I did fine a vacuum hose that was tied down to the tranny dip stick with a cap on it does any body know what that could be Thanks
Old 02-25-2006, 05:24 AM
muddog321 muddog321 is offline
AF -Advisor
Re: Howling noise
That would be the trans vent line tied to the trans dip stick tube put there to keep water out of it. If that CV boot has split and all the grease came out or was washed out that CV axle is probably the noise source, if not now it soon will be so change it out - about $75 for a rebuilt axle. You never said how many miles this has on it but if a 96 look at the U-joints on the rear driveshaft. Check the gear oil in the front diff now! Yes there are bearings and seals in both sides and the pinion. Brakes are usually more of a grinding noise when really bad. Remember that noise sources are often coming from other areas than they seem to be (pain to find).
