Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
View Poll Results: What would you want recalled most?
Door Window Seals 1 16.67%
Head Gasket 3 50.00%
Timing chain/belt--Water Pump 0 0%
Sensors (anytype) 0 0%
Fuel Sending Unit 1 16.67%
Instrument Cluster 1 16.67%
Clutch Assembly 1 16.67%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Old 02-05-2006, 01:45 AM
ryandotcom's Avatar
ryandotcom ryandotcom is offline
Send a message via Yahoo to ryandotcom
Exclamation Recalls, which would you want?
With all the problems the Neons have, and they all seem to be pretty common from what I have read on here. Which recall would you want to see taken care of most? It just blows my mind at how everyone can relate to each problem. These are the recalls that i found on www.Autozone.com for the 96 Neons. So place your vote on what should be recalled.TitleNumberDateCampaign - Air Cleaner Drain66011/01/95 Recall - Engine Wiring Harness Routing67602/01/96 Recall 96V026000: Engine Wiring Harness May CircuitNHTSA96V02600002/02/96 Recall 96V075000: Brake Master Cylinder LeakNHTSA96V07500004/30/96 Recall - Master Cylinder Primary Piston68706/01/96 Recall - Reprogram (flash) PCM67809/01/96 Recall - Radiator69410/01/96 Recall - Passenger Air Bag Safety71204/01/97
Old 02-05-2006, 09:35 AM
G-man422's Avatar
G-man422 G-man422 is offline
Re: If there were recalls, which would you want?
i say door seal.
Old 02-05-2006, 09:57 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Yes the neon had/has some problems, but people need to remember it was in it's first 5 years of production. The second generation neons didn't have as many problems, and if they had kept it going it probably could have been a real nice reliable car, like the civic, which jas been in production for 30+ years now.
