| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
4.3 Vortec cpi pic - need regulator?
hmm.... posting rules state i cannot post the pic.
anyway, the passenger side of the plenum looks washed. how do i know it is the regulator? also does the regulator Help! part # 55162 work on a 1993 4.3 Vortec? Autozone stated it will not. that they only sell the whole injector for this year. is this so? thank you, tony |
#2 | |
Re: 4.3 Vortec cpi pic - need regulator?
You can post the pic, post it and lets have a look.
![]() 1996 Blazer LT 4 Door, 4x4, 4.3L Vin W. |
#3 | ||
#4 | |
![]() leadalto - just got done reading about your situation. read alot about this cpi thing. yeah, pics are the ticket. not sure what resoution to use though. i could make this bigger but what is the limit? |
#5 | ||
Your picture looks very similar to the one I posted and the washing on the passenger side looks even more pronounced than mine. The following words and picture are what I posted a few weeks ago: "I took a picture with another camera looking straight down, Adjusted the image for contrast, color , etc. Is the small washed area, as pointed, what you suspect is a pinpoint leak in the nut kit? If so, it looks like it's on the return line side. There is also a big difference in the color of the spider tubes (and nut kit plumbing) from the passenger to drivers side." ![]() Since then, I replaced the spider and Nut Kit which solved the problem I had with Rich mixture, black smoke, lots of carbon stains on the driveway, and qualifying as a gross polluter on my smog test. |
#6 | |
AF - Advisor
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005
If you have the plenum off. Prime up the fuel pump and watch for leaks.
Disable coil or dist and bump the key on and you should get a fuel pump prime or jump the fuel pump primmer wire and let the fuel pump run and to get more pressure on it pinch the return line. If it is leaking you should be able to see the leak. Check around fuel reg and the plastic inlet and return lines. referred to as the nut kit by gm. Most of the older ones you have to replace the whole fuel spider assembley unless some one makes a replace fuel reg now. MT
#7 | ||||
For myself, these questions are moot because I've just replaced my spider and nut kit but they were important to me at the time, and still are. |
#8 | ||
AF - Advisor
There is a couple of rubber hoses on the fuel lines . large one pressure and small one return. Pinch off the small return line at the rubber part or remove it and plug for full fuel pump pressure around 75-85-90 lbs fuel pressure. It gives you a good idea how good the fuel pump is and helps find them leaks. Another good indication of a leak is a fast leak down of fuel pressure. MT
#9 | ||
#10 | |
GM S-Series Mod
![]() Join Date: Aug 2005
from what i've heard from others, the fuel regulator is now availible at places like advanced auto.
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
#11 | |
look throught the phone book for a auto parts warehouse in your arean they sell a regulator for you blazer! it is about $50.00 i know b/c i just got one and since every part is a common part on blazers they usal stock them or can get the regulator for you......
#12 | |
Re: 4.3 Vortec cpi pic - need regulator? update
replaced regulator. new plugs (old were fouled).
egr moved fine, manifold passage was open. electronic control module checked out fine from testing at auto zone. motor has good spark. idles fine but big time bogging upon acceleration. not drivable. going to purchase fuel pressure gauge and check with key on. probably will pull the plenum again. i did not key on with the plenum off before. plese add comments if i missed anything. |
#13 | ||
I thought I'd save a few bucks on a fuel pressure guage by getting a Chinese knock-off at Harbor Freight Tools (a cheap tool retailer on the West Coast and possibly other areas). They had one with a GREAT price $9.99. Hooking it up to the Shrader valve, I looked forward to measuring the fuel pressure but a major problem occurred when gasoline started filling-up in the guage readout. Well, I thought somebody probably forgot to install an "O" ring or whatever during the assembly process so I exchanged it for another one. Same problem except I was getting tired of exchanging defective junk. After shopping around, the best deal I found was at an Autozone. They had two choices. One for about $35 which had a short hose and another for about $55 which had a long enough hose to route into the passenger compartment. I bought the $35 version and guess what, no gas filling up the guage readout. Now that I have a fuel pressure guage, I'm hoping I never have to use it again! |
#14 | |
yeah was going to get the one from auto zone.
also, my spark was yellow not blue. if i pull the plenum off and there was a leak in the spider and/or nut, wouldn/t there be fresh wetness or small fuel puddles liek before in order to verify? |
#15 | ||
It shouldn't take more than 1/2 to 1 hour to pull the plenum but take care in tagging the bolts because they're all various sizes and some don't come out because they're guide pins. I used a piece of plastic foam and pushed the hardware into it to keep the pieces separated. Not believing that I had a bad regulator, I even reused the gasket temporarily to do some additional testing (there was no visible damage to the gasket) by coating both sides with vaseline and reinstalling the plenum. I really never found out whether the failure mode was a bad regulator, leakage, stuck injectors, or whatever; however, after $320 in parts for the spider and nut kit (the nut kit was the most difficult part of the replacement), everything's running great. |
