Good information about the problem. Detailed instructions on how to repair it yourself and save some big $'s on labor.
www.autoclinix.com |
Re: 4.6L Cracked Intake Manifold Repair
Ford did a recall on some intakes...i did not read the link but before you pay anything call dealership to see if the recall applies to you have your VIN number on hand.. i've had two crown vics and each was covered. they will not fix ignition coils,plugs, or oxygen sensors that might have gotten damaged due to leak...they will change intake free of charge
I just bought a 97 cv lx, and the guy i bought it from already had it replaced,because it had cracked and was spraying fuel out near the fan. I had heard it is a decent size job..Glad I dont have to do it..
My car is leaking rad fluid, its coming from around the top of the thermostat housing.. does anyone know how to fix this? Im hoping its not the damn manifold
Normally, a ruptured manifold is going to dump coolant very quickly and cause your to overheat in a matter of minutes. If you have a slow leak it's probably not a ruptured manifold. What year car and how many miles? |
its a 96 with 323 000 kms, i took the hose off and found that the thermostat housing was cracked so i used cold weld on it and dumped sum stop leak in and it has been 1000kms so far and nothing.. so ill keep my eye on it.. i appreciate all the help . thank-you and take care
