Go Back   Automotive Forums Car Chat > Toyota > Supra > Performance
Performance Talk about anything having to do with performance & mods.
Old 11-18-2005, 08:18 PM
sleepersupra sleepersupra is offline
Send a message via AIM to sleepersupra
profecB boost controller help
i just got a prfec b spec2 boost controoler, i know that one vaccum line is ran into the line of the fuel pressure regulator. i dont know where the other line goes, can someone help me
Old 11-18-2005, 10:53 PM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Re: profecB boost controller help
The line dose not go to the fuel press. regulator. Boost controllers mount in the waste gate intake manifold reference line. You should have two ports on the boost controller. One line connects to the intake manifold. The other line connects to the waste gate. Did your boost controller come with a manual? You will need it for the wire diagrams, operation instructions, and to identify which port is manifold reference and which port is wastegate signal.
What else are you installing with the boost controller? A boost controller should not be installed or tuned without a piggy back fuel computer to compensate for the added air flow. You will need a new boost gauge becaues the stock unit cannot read higher than stock pressures. You will need some way to monitor air fuel ratio while tuning the car. If you have not thought of these things, I would reccomend consulting a shop before proceeding.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 11-19-2005, 08:19 AM
i connected one line to the wastegate and solenoid and one line to the turbo housing, and solenoid. i connected one line from the fuel pressure regualtor directley to the back of my the boost controller. the solenoid and boost controller is connected by a wire. i followed the instructions and it seem to boost fine without any engine check light. i only set it at 25%
Old 11-23-2005, 12:29 AM
at stock the wastegate has a hose connected to the intercooler pipe, i disconnect the hose and connect the two hoses that came off of the control valve, the control valve is connected to the electronic controller with provided wires. the electronic controller has a vaccum hose that i split into the fuel pressure regulator hose for vaccum. it seems to be working. sorry for the confusion, i do have a manual and i did follow it. i just wanted to make sure from someone more experience. what piggy back u recommend?
Old 11-23-2005, 04:15 AM
TcmaBoy's Avatar
AF - Advisor
You have it like this?
Old 11-24-2005, 07:49 AM
yes,that looks like the way i connected it. the line out are two wires that connect to the valve, which has two hoses that i connected to the actuator and the turbo housing.
