i found some information i was send before about the draging . but i was forgrtting it . it is useful for me and i hope for you too i think i know what i need look :92 to 95 Civic's
Basic Info You can tell a DX/CX/VX tranny from a EX/Si by numbers cast into the housing. Just above the filler plug is a set of numbers. P20/A000 is for DX/CX/VX P20/B000 is for EX/Si Other than that, tranny must be split apart to know for sure which one you have. Available Stock Ratios EX/Si 1st-----3.250 2nd-----1.900 3rd-----1.250 4th-----0.909 5th-----0.750 for Si HB and Del sol Si or------0.702 for 2 dr or 4 dr sedan Final Drive---4.250 DX/LX 1st-----3.250 2nd-----1.762 3rd-----1.172 4th-----0.909 5th-----0.702 Final Drive---4.058 CX /VX 1st-----3.250 2nd-----1.761 3rd-----1.066 4th-----0.853 5th-----0.702 Final Drive---3.250 Internal Differences There are some minor differences, mainly with the bearings inside the trannys. The diff bearings, countershaft bearings, and input shaft bearings are different between the DX/CX/VX casings and the EX/Si casings. If you are putting a EX/Si gearset into a DX/CX/VX casing, you have to use the second countershaft bearing and the differential of the case you are swapping into. NOTE The bolts for the ring gear are lefthanded thread. Weak Points The major weak points are the shifter forks and the diff. gears. The shifter forks are made out of cast aluminum. They are prone to rapid wear, so be cafeful when downsshifting into first gear, esp. when racing. DO NOT force it into first gear. The fork will break! Another weak point is the gears inside the differential. They are cast steel and prone to failure. If a HD clutch or slicks are used, the diff. will fail sooner or later. The best thing is to install a quality LSD (Limited Slip Differential) as I've broke two trannys from this. Beware of the Phantom Grip LSD as it uses stock gears. It might be OK for autoxing, but AVOID it for drag racing. 5th gears You can swap any of the 5th gearsets for cruising at a higher/lower rpm. This is a simple swap, once your inside the tranny. The 0.771 from the 4g Civic/CRX L3 trannys fit perfectly and is a nice swap to a DX/EX/Si 0.702 5th. Make sure you keep the gearsets with each other. It is very easy to get the 27 tooth gears mixed up. They are very close in size, but will not interchange. You have the following choices. 0.878---??/??---CRX ZC JDM 0.771---35/27---Civic/CRX 88-91 DX/Si 0.750---36/27 0.702---37/26 0.694---36/25---Civic/CRX 88-91 HF The mysterious VX 5th of 0.673 was a misprint in the 1994 Honda Service Manual. It was the 4th gear ratio of the automatic tranny. It is best to use either the 0.771 or 0.750 with stock or lightly modified engines. You can get by with the 0.702 but mileage will be about the same. RPM vs. MPH of various 5th gears 5th gear-----FD------45------60------80------100--- 0.702------4.058---1898---2530---3373---4217-- 0.702------4.250---1988---2650---3533---4417-- 0.750------4.250---2123---2831---3775---4718-- 0.771------4.250---2183---2910---3880---4850-- 0.878------4.250---2486---3314---4419---5523-- Multiply RPM's by 1.135 if using 20" slicks Multiply RPM's by 1.032 if using 22" slicks RPM shift tables These tables will tell you how much your rpm's will drop when shifting. These numbers are for a steady speed shift. If you are accelerating they will be slightly higher due to clutch slippage and continued acceleration. Hybrid trannys also included. MPH numbers are for stock size tires, 22.7" overall diameter. MPH numbers for 5th gear are assuming enough power to overcome wind drag. How to use these tables...If you shift at 6800 rpm using the DX tranny as an example, your rpm will fall to 3685 in 2nd, 4526 in 3rd, on so on. DX 1st----3.250---0000/6800---34.8mph 2nd---1.761---3685/6800---64.3mph 3rd----1.172---4526/6800---96.9mph 4th----0.909---5274/6800---124.5mph 5th----0.702---5251/6800---161.3mph Si/EX 1st----3.250---0000/7200---35.2mph 2nd---1.900---4209/7200---60.2mph 3rd----1.250---4739/7200---91.6mph 4th----0.909---5236/7200---125.9mph Choose your 5th 5th----0.702---5560/7200---163.0mph 5th----0.750---5941/7200---152.6mph 5th----0.771---6107/7200---148.4mph Hybrid using ZC 3rd and 4th gears 1st----3.250---0000/7200---35.2mph 2nd---1.900---4209/7200---60.2mph 3rd----1.346---5101/7200---85.0mph 4th----1.033---5526/7200---110.7mph 5th----0.750---5228/7200---152.5mph For 92-95 trannys it is best to use the HF/STD 3rd gear of 1.033 for 4th gear. If you use the ZC 4th gear it will require grinding to fit the synchro hub. hope i add info for you. Hany http://home.cinci.rr.com/mistab0ne/tranny.html
MY ENGLISH IS NOT PERFECT. sorry for that 1992 CIVIC 4DOOR ULTRA BLUE TURBO -SOLD 1996 CIVIC 4DOOR EUROPIAN VTEC LS 2003 CIVIC LXI 1999 GOLF 4 1400 CC |
