Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 10-07-2005, 06:18 PM
woolybuddy woolybuddy is offline
Cool 00 sunfire sputtering constantly
2000 sunfire- automatic 2200
sputtering when maintaining speed on highway, accelerating, at a light- basically anytime after it is started. diagnostic test won't read because it has wiring problems. plugs are new. Is it the coil, wire, crank position sensor, or an injector?
Old 10-08-2005, 08:14 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 00 sunfire sputtering constantly
Try changing spark plug wires. If the plugs are new then change the wires or connectors whatever the case may be. If that doesn't correct the problem then change coils. Finally, make sure you check the fuel pressure on the car. If the fuel pump or fuel pressure regulator are going bad then fuel pressure is the proper way to check it.
Old 11-22-2005, 07:57 PM
the80schild the80schild is offline
Send a message via AIM to the80schild
Re: Re: 00 sunfire sputtering constantly
-- I had the same problem with my 00 sunfire...with mine it turned out to be the a wire and the coil.
