Old 09-26-2005, 09:36 PM
old-school old-school is offline
93 PA quit while driving, no spark, no pulse
My 93 quit the other day while driving, Codes 42 & 58 Cranks perfect, but no spark or injector pulse,
I installed a new crank sensor and still no start,
I inspected cam sensor and magnite on cam gear and all appers okay.
I installed a used ignition module and coil assemblies, still nothing.....Any ideas??? Thanks
Old 09-27-2005, 05:29 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 93 PA quit while driving, no spark, no pulse
I looks like your next part would be the PCM, however normally the engine should fire (spark) on the ICM for a few seconds, (enough to start) and then hand it over to the PCM. Try a used PCM first. You would need to change the prom from the old unit to the newer unit also.
Old 09-27-2005, 05:32 PM
wmrivera wmrivera is offline
Ignition Control Module went out. Mine has done it twice in 3 months. It's right under the coil pack, easy to take out, 3 bolts. costs about $90 - HOLD ON TO YOUR RECEIPT it will come in handy when it happens again!
Old 09-27-2005, 05:46 PM
kok328 kok328 is offline
"HOLD ON TO YOUR RECEIPT it will come in handy when it happens again!"
I'm not aware of any auto parts store that put a guarantee on electrical parts.
Old 09-27-2005, 05:54 PM
Advance Auto has always done it for me
Old 09-27-2005, 06:12 PM
HotZ28's Avatar
AF Moderator Elite
" I installed a used ignition module and coil assemblies, still nothing"
From the original post "old-school" had replaced the ICM and coils with a used unit! Highly unlikely both are bad however, I guess anything is possible.
Old 09-27-2005, 08:46 PM
Thanks for the ideas, perhaps I should replace the cam sensor, what about the ignition key resitor type security system, does it disable crank or spark,?? Thanks Again Pat
Old 09-28-2005, 04:17 PM
Re: Re: 93 PA quit while driving, no spark, no pulse
If there is a problem with the security, then nothing happens, wont turn over or anything
