Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-30-2005, 04:21 PM
Max-97CivicEx Max-97CivicEx is offline
06 Camry Auto-Lock question
Silly question time, my mother just got 06 Camry LE and when she drives, the doors lock, however unlike her old Camry, when she stops, the doors do not automatically unlock. Is this normal behaviour? Is there a way to change it to auto-unlock?
She does not have an alarm, if this matters.
Thanks
-M
Old 08-30-2005, 06:58 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 06 Camry Auto-Lock question
I don't know, but you should be able to find out by reading her owner's manual.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-30-2005, 08:09 PM
csaxon csaxon is offline
Try this. Move shift lever to P and close all doors. Turn ignition switch to the "ON" position. Then, quickly, within 10 seconds push and hold the main power door lock switch in the unlock position for 5 seconds. All doors will automatically lock and unlock when you release the power door lock switch. This puts the auto door lock function to Mode B. If it doesn't work retry and do it with the time limits I gave. The 5 seconds has to be almost exact.
It worked fine until I fixed it!
Old 08-30-2005, 08:50 PM
Brian R.'s Avatar
Resident Chemist
Someone at Toyota has way too much time on their hands figuring out these codes.
Old 08-31-2005, 01:52 AM
Re: Re: 06 Camry Auto-Lock question
Yeah, that would be much easier if we were on same coast :-/
Thanks, I'll have her (or better yet my dad) try it. Now, to cover my butt, if she does not like "Mode B" - how do I reset it back to Mode A (or whatever mode it is in by default) - do I just repeat same?
Thanks again.
-M
Old 08-31-2005, 01:40 PM
Brian R.'s Avatar
Resident Chemist
or walk her though the manual
Old 09-02-2005, 09:23 AM
Max-97CivicEx, there are 4 different modes for the door locks. There is info in the owners manual on how to change the locking preferences. The various modes are for the service techs and the pre-delivery inspection people if they have to disconnect the battery for some reason which puts the door locks into the default mode. For some reason trucks are mode a,b,c,d and cars tend to be mode 1,2,3,4. When the battery is disconnected it returns to default setting mode 1 which keeps the doors locked when the transmission is in P. 1, 4 keep doors locked and 3 "unlocks" the door in P. I haven't seen the 06 Camry but if it has the interior light switch on the left side of the dashboard by the door then it must be rotated to the DOOR position which is the line below the ON position. Because the interior lights blink with the various settings. I can go on forever but the easiest solution is to READ the OWNERS MANUAL, it's in there.
