Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 08-23-2005, 01:11 AM
74_novacustom 74_novacustom is offline
Question smog
hey my fellow nova peeps.
i am going to remove all of the smog stuff off of my car and was just curious as to if there will be a noticable power difference? i know it will not be an insane difference but just wantin to know if it will perform any differently. thanks guys
Old 08-24-2005, 10:53 AM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: smog
What do you mean by all of the smog stuff? What exactly are you doing to the car?
Old 08-24-2005, 11:25 PM
Re: Re: smog
the A.I.R. pump and maybe the egr and pcv.
Old 08-25-2005, 09:46 AM
Re: smog
If you have the stock 350 with 160hp you might get 180 - 190. But it'll run a lot better. After you do it just get it dynoed to be sure.
Old 08-25-2005, 05:45 PM
Re: Re: Re: smog
i have the 1988 goodwrench 350 with 265hp but besides dual ehaust it is pretty much stock. the guy who had it before me put a new engine in 88. so would i say 285-95??
Old 08-26-2005, 03:21 AM
Re: smog
Well it very well could be. I'm not sure though I haven't heard of the goodwrench 350.
Old 08-27-2005, 10:37 PM
CRushER CRushER is offline
Send a message via AIM to CRushER Send a message via MSN to CRushER
Re: smog
Definately do not remove the pcv, it helps the gases that get caught in the crankcase to recirculate and get burned in the engine, if those gases stay there they can cause the oil to become a little bit corrosive and damage your engine. The EGR I would keep also because it helps controls engine temperature and also helps your fuel economy. If your inclined too you can remove the egr, but I would definately keep the pcv. Removing that won't cause any power increase because it's ran off of a vacuume line iirc. The air pump just gives air to the exaust and allows combustion even after it leaves the cylinders to help burn the extra fuel that wasn't consumed during combustion to make emmisons better. If I'm wrong guys please correct me.
Old 08-28-2005, 03:31 AM
CivicSlayr's Avatar
CivicSlayr CivicSlayr is offline
Send a message via AIM to CivicSlayr
Re: smog
"The air pump just gives air to the exaust and allows combustion even after it leaves the cylinders to help burn the extra fuel that wasn't consumed during combustion to make emmisons better" I tkaes power to spin that pump. Take it off and your freeing up power, but worsening emissions.
Old 09-06-2005, 08:47 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
All in all, do be prepared for the fact that your car might run worse with the emissions equipment off it. Everything was designed to work together from the factory. I was a big believer in taking off all the pollution devices until I had trouble with getting a 350 to pass the local emissions testing.
Bob
