| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
Has anyone done their own work on replacing parts to the stering linkage?
My front end needs work ,I have some play in my stering and when I got an estimate to get the work done they quoted around $500-$600.I would like to do the work myself to save some cash, is this hard to do or fairly reasonable and can you give some advise along with some pointers. THANKS
#2 | |
Re: Has anyone done their own work on replacing parts to the stering linkage?
most of it should be replaceable DIY with a good picklefork and rapport with your parts dealer. hard to tell if their price is out of line, tho, with the limited information at hand... how much of it were they going to replace? and this IS on your '97, right?
#3 | ||
Re: Re: Has anyone done their own work on replacing parts to the stering linkage?
#4 | |
AF -Advisor
![]() Join Date: Sep 2003
you need to know what they are replacing.
This is a tough job to do.
1995 Factory Blazer Service Manual for sale, PM if interested. |
#5 | |
Problem?
![]() Join Date: Dec 2004
I've replaced steering parts on many cars and it is a fairly simple procedure. I haven't had to replace anything other than the idler arm on my Blazer, because proper maintenance will keep everything functioning well for a very long time.
The cost was about $200 for parts on the last vehicle I did. That was for: 2 inner tie rod ends 2 outer tie rod ends 2 tie rod sleeves 1 idler arm If you have to replace the pitman arm, too, it will make the job harder, but that is the only thing difficult about it. After replacing the parts, you will need to check the alignment. I do my own, but if you haven't done it before and don't have someone to walk you through it, it is better to just pay to have the alignment done. The only special tool needed is a picklefork (tie rod end separator), they cost about $10. You can pick up a haynes manual for less the $20 and it will give you pretty good instructions. It is best to take off one complete side at a time (inner, outer tierod ends and the sleeve. DO NOT loosen the nuts on the sleeve or it could move and the measurement will change) and preassemble the new parts to the exact length of the old ones, this will keep your alignment very close. |
#6 | |
Problem?
and make sure that you grease the new parts after installing them. You wouldn't believe how many times that I've seen people install new parts and not grease them.
#7 | |
And how many auto parts stores will LET those new parts go out the door without the required "zerts"(grease fittings)...
Amen and amen to my cohorts above... What some see as easy can be tough for others. |
#8 | |
[quote=blazee]I've replaced steering parts on many cars and it is a fairly simple procedure. I haven't had to replace anything other than the idler arm on my Blazer, because proper maintenance will keep everything functioning well for a very long time.
The cost was about $200 for parts on the last vehicle I did. That was for: 2 inner tie rod ends 2 outer tie rod ends 2 tie rod sleeves 1 idler arm If you have to replace the pitman arm, too, it will make the job harder, but that is the only thing difficult about it. After replacing the parts, you will need to check the alignment. I do my own, but if you haven't done it before and don't have someone to walk you through it, it is better to just pay to have the alignment done. The only special tool needed is a picklefork (tie rod end separator), they cost about $10. You can pick up a haynes manual for less the $20 and it will give you pretty good instructions. It is best to take off one complete side at a time (inner, outer tierod ends and the sleeve. DO NOT loosen the nuts on the sleeve or it could move and the measurement will change) and preassemble the new parts to the exact length of the old ones, this will keep your alignment very close.[/QU Thanks for the info it what useful , I went and got a manual and it described the details pretty good for procedures. I'm glad that I found this forum persons can learn alot from one another Thanks again to all (My main problem with things is I procrastinate on getting to things right away... it needed an alignment awhile ago but kept putting it off and now I'm fixing things on my blazer that probably wouldn't have been so bad if I got to it sooner... ) |
