Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 07-31-2005, 02:13 AM
glaSSpax glaSSpax is offline
Arrow 1970 Mav Brake-Over...
Hey All, Thanks for checkin' out this post.
I.m about to purchase a 1970 Maverick from a buddy of mine. It still runs but will need much work. The engine is original straight 6 and the tranny is oem too.
My question is: what all do i need in order to change the brake system over to disc ? And is it very complicated?
When making the chang-over, will I need to do anything to the rear brakes?
Thanks
"If everything seems under control, you're just not going fast enough."
Old 02-27-2006, 09:19 PM
kaskillah's Avatar
kaskillah kaskillah is offline
Re: 1970 Mav Brake-Over...
You could get the front disc brakes from a later year Maverick or maybe even a Fairmont. You would need to change the knuckle/spindle assemblies. For the rear, you will probably have to swap a rear end from another Ford product. I have heard you can use the rear end from a Lincoln Versailles because they had disc brakes though I never heard one used on a Maverick.
I had an early model 1970 Maverick in the 80's. It was a bullet-proof car. I couldn't kill it. The drum brakes on the rear end are more than adequate. The front brakes sucked because anytime you would run through a deep puddle you can lose them unless you applied the brakes when going through it.
Honestly, I don't think it's worth the trouble to make the change unless you were also thinking about dropping a V8 in it.
1984 Mercedes Benz 230CE (171K)
1985 Mercedes Benz 300DT (244K)
1987 Mercedes Benz 300DT (254K)
1999 Chevy Tahoe LS 4X4
1977 GMC Sierra Grande 4X4 (90K)
"When life hands you lemons, ask for tequila and salt!"
Old 03-13-2006, 10:00 AM
e_powers e_powers is offline
I agree. i had a 1972 maverick and i redid all the brakes on it and as i recall the rears were the easiest drums i ever done. except when i needed the drums replaced. it was hard finding a machinist to press in the new lugs in the drums as the process used is not done any more and i needed to find someone who remembered how
