Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 07-28-2005, 12:17 AM
Busibanker Busibanker is offline
'01 Trooper Stalling
I have an '01 Trooper with 109,000 miles. Problem started about 6 weeks ago. The car starts OK, runs OK for maybe 5 minutes or so, but then when I slow to make a turn or stop, the engine dies. It has always started right back up, but obviously a pain.
I've had it at the dealer three times. They've changed out the EGR valve, a trans mode sensor and a throttle sensor (I think I have those right). This has still not fixed the problem. The dealer suggested running two tanks of "good" gas...still no fix. Prior to this problem occuring the Automatic Transmission Temperature light came on when I was towing my camper. We pulled over, let the vehicle sit a bit, the light went off and hasn't come back on since. I've since had the transmission serviced and a transmission cooler installed.
Just before the car dies, there's a bit of a vibration noise and the air conditioner will stop. If I can catch it before it dies, put it in neutral and rev the motor, it won't die. This seems to happen more right after I've started driving it. As long as I'm giving it gas, it won't die.
What do you do when the "experts" (the dealer) can't figure out what's wrong. It's one thing to have to deal with paying for repairs, but when the dealer can't even tell you what's wrong, it very frustrating.
Any suggestions would be appreciated. Thanks!
Old 07-28-2005, 08:59 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: '01 Trooper Stalling
sounds like a classic intake manifold gasket problem.
see the FAQ's.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 07-28-2005, 06:03 PM
Re: Re: '01 Trooper Stalling
see the FAQ's.
Is this an expensive repair...any ballpark estimates???
Thanks for the reply
Old 07-28-2005, 09:34 PM
mlingk mlingk is offline
I did my own repair.. not too difficult. I believe I paid the dealer $75 for the gasket at the time. The FAQ has info on how to do it. Probably around $200 in labor for a shop to do it, although, anyone who has done it once should be able to do it in around an hour or so..
Old 07-28-2005, 10:45 PM
Smile
Thanks so much. I'll certainly make this suggestion to the dealer.
Old 07-29-2005, 07:36 AM
I wouldn't be making suggestions on how fast the dealer should be doing their work They have standard rates for these things anyway so it won't matter. Of course, I had a FireStone once tell me I needed a new serpentine belt and would cost $160 or so because they had to move the alt or AC or some shit.. I said no. Went home it it took me only 10 minutes, and that was the first time I had done it on the truck.
Old 07-29-2005, 09:55 PM
I'm holding out hope that I won't be out any more money. I took the vehicle to the dealer with a problem. $800 later it's still not fixed. My stance is going to be fix the problem, or refund my money. Too bad, so sad if you've done work...replaced parts, etc. I'm taking Troopy in on Monday. It's amazing that something like a car repair can take up so much of your life.
Thanks for the response.
Old 07-30-2005, 08:17 PM
rodeo02 rodeo02 is offline
The intake manifold gasket replacement will be a freebe fix for you for 10yrs/120K miles if you are the original owner. This is a VERY common issue for the 1998+ 3.2/3.5 engines. If your dealer is not familiar with this, try another dealer!!
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
