Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-27-2002, 12:03 AM
nemesls_2000's Avatar
nemesls_2000 nemesls_2000 is offline
Send a message via AIM to nemesls_2000
Which mods have you found to be most beneficial?
For those of you with 98 GSR motors, aside from i/h/e, what kind of mods have you done nd which have you found to have the most gains?
Mods:
AEM intake, DC Sports 4-1 header, Tanabe exhaust w/ 2.5" custom piping, ITR exhaust cam, APEXi VAFC, AEM FPR, Warlboro 255l fp, RC 440 injectors, ACT stage 3 clutch, JR Supercharger, Weapon R coilovers, VIS CF vader hood, CF Angel Eye Projector headlights, Black housing corners w/ amber bulbs, "Hybrid" rear emblem, custom rear speaker panels.
Old 04-27-2002, 03:55 AM
M-type M-type is offline
other than those mentioned, its not really worth it to get anything else. just build up the internals and boost it or na tune it.
Powered by Honda. NA tuned at 11.8:1
Old 04-27-2002, 11:15 PM
What about a pulley kit or cam gears? Do you have a VAFC hooked up?
Mods:
Old 04-29-2002, 01:43 PM
threethirteen's Avatar
threethirteen threethirteen is offline
Send a message via AIM to threethirteen
internals.
nothing can beat the power of a nice set higher compression pistons...and some new sleeves...rods...
i would definately say internals...the harder it is, most likely the more power you are going to get...and pistons aren't easy...
Letting micheal jackson in into disneyworld is like letting a kid in a candy store...or like a child molester in a candy store...looking for kids.
Old 05-01-2002, 07:30 AM
Marasmus Marasmus is offline
Send a message via Yahoo to Marasmus
The basics...
The tires and intake will make the most immediately-attainable difference. The stock exhaust on the GS-R is actually quite good, and next-to-no gains will be met until the engine's internals have been replaced or the engine is being boosted. If you're looking to put a B18C into your car, I wouldn't even start the motor with the stock exhaust of the Civic CX!
If you're looking for a kick-ass all-motor monster, think along these lines:
1. Tires. No more Michelin! Ever!
2. Intake (10? hp regained from the awful stock box)
3. Exhaust, headers (2.5in pipe) and port-matching the new headers (will actually hurt you until you get to the valvetrain)
4. Intake Camshaft from B18C5 (ITR) and cam gears (supposedly 16hp)
5. lighter rods, lighter, high-compression pistons, 2 more crank balancers (varies greatly)
6. valvetrain (springs, valves, sleeves, rehoned seats)
7. fuel pump, fuel rail, fuel pressure regulator, bigger injectors. you WILL NEED these to avoid exploding after step 7.
8. ECU (extend fuel map to 12,000 rpm, raise redline to ~10,000)
9. Either a new intake manifold or a completely reworked GS-R manifold (port matched on the head)
10. wider wheels. size specs are very much a preference thing. Just get something with so much patch-on-the-ground that you can't chirp anymore.
11. Rebuild tranny. Get 2nd, 3rd gears, final drive, LSD, synchros (all gears!!) from an ITR. Make SURE the synchros are perfect.
This will cost a ton of money ($5000 or more), but that should put a B18C in the range of 250-275hp to the wheels. Pulling high 11's in the quarter and a flat 5.0 on 0-60. Best part is, it will still be peaceful enough for a daily driver (provided you didn't put completely insane pistons in on step 5!).
Oh yeah... Don't forget a new clutch, flywheel, and suspension somewhere in there. whoops
Old 05-02-2002, 07:15 PM
THE4TH's Avatar
THE4TH THE4TH is offline
Send a message via AIM to THE4TH
cam gears, pulleys, flywheel, pistons, and vafc.. but the vafc isn't worth much till ya get some good mods goin on then it really makes it worth it..
S2000
Old 05-11-2002, 05:47 AM
PiNoY GsR RaCeR PiNoY GsR RaCeR is offline
Whats a good compression ratio for a B18C1 when getting new pistons? Whats a good brand?
1994 Acura Integra GS-R
Performance Mods:
AEM Intake
DC Sports Headers
GReddy Cat Back Exhaust
Ground Control Coilovers
Exterior Mods:
WW Body Kit
PIAA Low Beam Bulbs
'98 Style Integra Taillights
Old 05-16-2002, 03:30 AM
NEED4SPEED NEED4SPEED is offline
"HONDATA"
Without management/tuning you will not and shall not get maximum performance out our your engine. WORD!
Check out their site www.hondata.com
Even NA stock engines are pushing hard gaining more hp and torque than some of your mods combined (i.e. i/h/e)
I couldn't have done it w/o hondata. I wouldn't have believed it if i didnt see it for myself.
Which Ferrari's have you guys seen? DavkeG Cars in General 3 03-11-2004 04:10 AM
Which Ferrari's have you guys seen in real life ? DemoX General Discussion 26 02-05-2004 07:57 AM
what kinds of mods have you done to your prelude ? GOD Prelude 28 11-18-2003 12:46 AM
Which one do you like most? LauBak Car Modeling 31 02-06-2003 03:56 PM
Which decal do you want most? LauBak Car Modeling 12 10-07-2001 06:42 PM
