Old 07-08-2005, 10:19 AM
cujotom cujotom is offline
My 94 cav is a hard ride. it dont like bumps!
Hi guys any help would be appreciated. My 94 cavalier takes bumps very hard you feel everything. I have new springs and struts up front. Rear has new springs and shocks. If you look at the engine from up top and push the car backwards and forwards the engine moves back and forth alot.and i have new tires all around. is this just the way an 11 year old car should be or does something need to be looked at? you take quite a beating riding in this car... help
Old 08-18-2005, 12:22 AM
bluerazor bluerazor is offline
Re: My 94 cav is a hard ride. it dont like bumps!
If your engine moves that much you might have a couple busted/worn out motor mounts. You're actually feeling the engine rattling around hitting the metal parts of the motor mounts when you hit a bump.
Old 08-18-2005, 04:17 AM
z24 fanatic z24 fanatic is offline
Send a message via AIM to z24 fanatic
yeah you might want to check your motor mounts soon
Old 08-18-2005, 01:05 PM
94VL 94VL is offline
My 94 2.2/man has a soft mount on the trans side,and there is vibration at low speeds.I have a new mount and will have to swap it out.I replaced the passenger side mount because the engine was actually moving left/right and not front/back!
