Old 06-29-2005, 05:13 PM   #1
agamo
agamo's Avatar
Send a message via ICQ to agamo Send a message via MSN to agamo Send a message via Skype™ to agamo
Lamborghini Murcielago 40 Anniversary
Hello All:
Well I failed to complete my Sauber C9 project for the LeMans contest, and here is the reason, I had a compromise to enter an special class in a local contest, and build this baby which required several modifications to put it close to the real one:
I built the 40 Anniversary version, which I found very interesting and love the color, the assimetrical interior color scheme is also nice.
I modified the chassis to move the wheels to its correct position, corrected the windshield leveled to the body surface, engraved the window frame which goes in carbon fiber, added the AcuStion photoetched set, fixed the headlamps, the interiors were fully detailed, the engine bay was heavily modified as well.
The paint its Cobra Colors: tricoat Vert Artemis, awesome paints, and thanks Leon for your great help, it came very easy to a happy end
And thanks also to Phill, he gave great help on the engine.
And here go the pics, they're a little on the dark side, I'm going to get new ones with better light, in the meantime...
I'm working in the building process, I'll post it latter, it's long.
I cut the whole rear section of the chassis to correct the height and position of the rear axle, at the front I separated the A arms from the suspension assembly and added 2.5 mm extensions to each one, the spindles where modified to correct height.
The mirrors were relocated cutting the body, the window frames were engraved and covered with carbon fiber decal, I left the door windows open, so added a little clear acetate to simulate the window in the lowest position.
The windshield wiper was made of almost ten parts using the arms of the plastic included in the kit, with the rest made with the PE set and some plastic and thin metal sheet for the air deflector and linkages.
The wheel centers are PE parts covered with gold metal foil, paint detailed and covered with clear resin, I cut the small triangular opening for the blinker.
The rear part was heavily modified to fix the body around the rear lights, I glued the rear fascia to make things easier, and perforated the fans, since they are visible through the photoetched grilles, I made a clear cover for the rear lights also, to get the correct look, the heat shield over the exhaust tips was also removed and replaced with a plastic one.
The engine received a complete carbon fiber treatment, the intake manifold cover was separated to detail all the components, all the linkage for the accelerator was added, also scratchbuilt the engine heads and added wires, sensors, tubes, hoses, alternator, steering pump, pulleys, belt, and some bolts and details.
Hope you like it.
Happy modeling!
Ramon Garcia
Puebla, Mexico
agamo is offline   Reply With Quote
Old 06-29-2005, 05:57 PM   #2
Apexi_N1
Re: Lamborghini Murcielago 40 Anniversary
Awesome!! Very nice looking built with great details and personal touch. Nice colour too.
I am sure you will do well in your contest
Apexi_N1 is offline   Reply With Quote
Old 06-29-2005, 05:58 PM   #3
g00eY
g00eY's Avatar
wow! good job on this, i really like the brakes!
g00eY is offline   Reply With Quote
Old 06-29-2005, 06:00 PM   #4
MPWR
Image Hosting Exceeded
MPWR's Avatar
Wow. Gorgeous build, and I love the color. (I've always prefered Ferrari's to Lamborghini's, but the CobraColors selections are weakening my resolve!) Nice engine bay detailing, and very clean build!
PHOTOBUCKET SUCKS
MPWR is offline   Reply With Quote
Old 06-29-2005, 06:04 PM   #5
Jaimenew
Jaimenew's Avatar
Smile Re: Lamborghini Murcielago 40 Anniversary
Excellent work, very awesome, and very clean
Really looks like a real car.
Jaimenew is offline   Reply With Quote
Old 06-29-2005, 06:09 PM   #6
Jaymes
Jaymes's Avatar
holy hell! You could trick people into thinking that it's your 1:1 car love the color and everything about it! So detailed and so clean
Jaymes is offline   Reply With Quote
Old 06-29-2005, 06:28 PM   #7
Whumbachumba
Whumbachumba's Avatar
That is the best image I've ever seen. The flags in the window make it look so damn real!
You should also make a scale dealer price sticker and put it in the window!
Current Project: '70.5 Camaro; Air-Cooled GB: '66 Beetle; Shelby 427 Cobra
Whumbachumba is offline   Reply With Quote
Old 06-29-2005, 06:43 PM   #8
360spider
360spider's Avatar
Excellent work Ramon, truly great model.
ItalianHorses.net
360spider is offline   Reply With Quote
Old 06-29-2005, 07:24 PM   #9
freakmech
freakmech's Avatar
Send a message via AIM to freakmech
this is Beautiful! im working on the Gallardo and then will probably build the Murc as im now inspired again. thanks!
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
freakmech is offline   Reply With Quote
Old 06-29-2005, 08:03 PM   #10
Eric Cole
Eric Cole's Avatar
That looks great. Very realistic and very well done.
Eric Cole
Other Model Pictures Here:
http://s5.photobucket.com/albums/y197/justdande/
Eric Cole is offline   Reply With Quote
Old 06-29-2005, 08:12 PM   #11
blubaja
blubaja's Avatar
Holy shit that is dam beautiful! You have great skill! If you take some outdoor pics, there is no telling the differnece between that and a real car! Cobra Colors paint is rediculously beautiful too! Wow! Keep up the great work.
Frank X.
blubaja is offline   Reply With Quote
Old 06-29-2005, 08:16 PM   #12
Whumbachumba
Re: Re: Lamborghini Murcielago 40 Anniversary
Frank X.
Those are outside, look at the trees, clouds, and flags reflections in the paint. It's just so beautiful and realistic.
Old 06-29-2005, 08:25 PM   #13
blubaja
blubaja's Avatar
Outside..oh..I meant outside next to real cars and such. lol Dam!!
Old 06-29-2005, 09:28 PM   #14
redstang423
redstang423's Avatar
absolutely amazing! nice build!!!!
redstang423 is offline   Reply With Quote
Old 06-29-2005, 10:10 PM   #15
Fusionrr
Fusionrr's Avatar
excellent work!!!! Love the detail.
Fusionrr is offline   Reply With Quote
