Go Back   Automotive Forums .com Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-07-2005, 11:13 PM   #1
3.0maxima
Post 2003 i35 air condition
Recently I have purchased '03 infiniti i35 and I have noticed that there was no freon in the system, after filling it, the air compressor engages regardless of the temperature (heat/air cond 60 or 90degrees) is is always on. Is this normal for infiniti, or is ther something not working properly,, any help will be appriciated,,,
Thanks
3.0maxima is offline   Reply With Quote
Old 06-08-2005, 04:08 AM   #2
Nahkapohjola
Nahkapohjola's Avatar
Re: 2003 i35 air condition
Thanks
Check out from the maint manual how filling is done & troubleshooting tables. Then take to a shop...
See links below, I guess '02 manual is ok.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Nahkapohjola is offline   Reply With Quote
Old 06-08-2005, 07:18 AM   #3
3.0maxima
I have done the onboard diagnostics via temp control unit (has built in diagnostic tool) checked all of the sensors, everything works fine heat/cold, accept that theair compressor is always on, i have also checked the plug on the condenser itself and there is 5v between two outer pins and voltage is not switchingto other pin with temp change, will look into it more and will update the posts..
thanks..
Old 06-08-2005, 08:56 AM   #4
Nahkapohjola
thanks..
The diags diagnose only new systems, those problems that may be planned... very seldom help.
It could simply be the compressor relay contacts jammed; find it and knock with screwdriver to loosen. Measure if it is always energized: if no voltage, Replace.
There is single +12V wire to compressor, supplied via relay contacts. This relay is supplied always from Fused +12V.
The relay coil gets Ign on Fused +12V (another fuse) and is grounded from ECU pin 21. When ECU pin goes down, relay is closed, compressor gets +12V.
If that ECU pin is always down, then its not the relay... ECU has the last word as it always disconnects compressor on full throttle.
Old 06-08-2005, 09:32 AM   #5
3.0maxima
Re: Re: 2003 i35 air condition
i forgot to mention that when the heat/air cond if off the clutch on the compressor releases.. could that still be a relay??
Thanks for your help..
Old 06-08-2005, 09:57 AM   #6
Nahkapohjola
Re: Re: Re: 2003 i35 air condition
That kinda drops relay theory off the shelf.
Put a multimeter with extension wire to the circuit and test drive and see if disconnects on full throttle. If so, ECU is OK, and your problem comes from A/C circuit board. That board might be quite expensive: howabout just living with this: tell like microsoft that from now on this is THE feature, not problem?
Where to connect tst probe is good question: i'd think easiest accessible is the single connector in the compressor. Unplug it, insert long wire inside (first bare it ½inch) and plug it back hoping it will be inside and make connection. Then route the wire outside onto pass seat, connect multimeter and tsts drive. Use duct tape.
To tst my AT gearlock, I built extension wire to TCU cable, see http://www.cardomain.com/ride/748507/15 ...but maybe not necessary in this issue.
Old 06-08-2005, 10:13 AM   #7
3.0maxima
Re: Re: Re: Re: 2003 i35 air condition
Thanks alot, will try it once i get home from work,,
