Old 05-25-2005, 06:45 AM
nolifeeffect666 nolifeeffect666 is offline
my honda civic sounds like its mis fireing
i have a 92 honds civic ex i just replaced the valve cover gasket cuse it was burning a little oil and while i was there i replaced my sparkplugs cap and roter i did the timing right it waz fine for a few hours then when im sitting at a red light she sounds like shes misfireing
Old 05-25-2005, 07:01 AM
CivRacer95's Avatar
CivRacer95 CivRacer95 is offline
srs biznis
Send a message via AIM to CivRacer95
Re: my honda civic sounds like its mis fireing
Check and make sure your spark plug wires are completely on all the way. Both on the distributor cap and connected properly to the spark plugs. If they are loose, then that would be the cause of your mis-fire. So, just make sure they are on tightly and secure.
AF Guidelines. Read and play nicely :
Just Click Here!
Old 05-25-2005, 07:24 AM
Re: Re: my honda civic sounds like its mis fireing
i checked that they were on tight
Old 05-25-2005, 07:26 AM
Re: Re: Re: my honda civic sounds like its mis fireing
the mis fire only happens like 15 seconds from eachother
Old 05-25-2005, 10:41 AM
CivRacer95's Avatar
srs biznis
Check your distributor then. Or make sure your spark plugs are tightened as well, but I'm sure you may have done that as well. Although, you may have to gap your spark plugs. I don't know though. Doesn't sound like a problem I'm too familiar with.
Just Click Here!
Old 05-25-2005, 11:15 AM
wold a spark plug bein loose be the prob
Old 05-25-2005, 01:16 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
what kind of plugs did you buy?? they may not be gapped right.
Old 05-25-2005, 04:27 PM
no i gaped them 2 4oseconds just like autozone said they meed 2 be gaped 2
Old 05-25-2005, 04:30 PM
im gonna see if a plug is loose or smothing
Old 05-25-2005, 04:32 PM
Re: Re: Re: Re: my honda civic sounds like its mis fireing
do you happen the know the mpg on the 1.5 leiter 4 cylnder cuz im only getting 200 2 a tank r/n
CivRacer95's Avatar
srs biznis
As long as they are gapped properly that shouldn't cause too much of a problem if there weren't. If you have tightened down your spark plugs, and you made sure your plug wires are hooked properly, then you should check with your distributor next. Just out of curiousity, did you hook up your plugs and wires exactly the same way you took them off or did you just throw them back on without matching them back to order? If I remember correctly, you have to put everything back in order properly. I don't know and I'm not quite sure about that either.
Just Click Here!
Old 05-25-2005, 04:40 PM
yes i did im bout to check and see if a plug is loose
Old 05-26-2005, 02:18 PM
wudini wudini is offline
Send a message via ICQ to wudini Send a message via AIM to wudini Send a message via MSN to wudini Send a message via Yahoo to wudini
i thought the EX coupe only came out in 94-95
Old 05-26-2005, 02:54 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
EX coupes have been available since 92 throughout all the years.
Empty Pockets Racing Member #1
Old 05-26-2005, 03:35 PM
Kind of a Big Deal
ya, i have a 93 ex coupe..
