Old 03-13-2005, 11:45 PM
t4ia t4ia is offline
1997 Dodge Caravan oil change
Hi,
I am new using Caravan. Just bought it a few months back. Can anyone tell me how difficult it is to change the Engine oil/filter and transmission oil on these vans if I want to do this myself. Which engine and transmission oil and filter are recommended. Does anyone have instructions on doing this (along with pictures if possible) or any site that explains this?
thanks.
Old 03-13-2005, 11:46 PM
forgot to mention that it is a Dodge Caravan SE with 3.0 V6 Engine.
Old 03-14-2005, 11:05 AM
jawss jawss is offline
An oil change is no prob. Jack the front of the van up and use blocks or stands. Just high enough to let you get under and your drain pan has to be able to fit easily. You can put your jack on the front motor/transmission mount ( the part thats bolted to the body). The filter is right in the front and is easily accessed while you're under the van. Use a funnel when pouring new oil in, less mess. Dont use cheap oil either. Im a Castrol fan myself. You pay a little more but its worth it. My motor has over 500 000 kms on it and its still going strong. Oil stays nice and clear.
As far as the transmission oils change goes, thats a little more difficult. If you're not a mechanic, I would advise that you take it to a tranny shop and let them do it. These Dodge trannys are very sensitive. One wrong move or using low-grade oil can ruin them.. fast! Also, the tranny shop will remove ALL the old oil, including whats in the torque convertor too. Dropping the pan off and changing the filter doesnt get all the old oil out. Its worth paying the money to get the pros do do this. Make sure its a reputable shop too. Also, as an added safety, if your van doesnt have a transmission cooler, get one! This will add longer life to your tranny.
Look through the front grill of your van on the drivers side and look for a small radiator-like piece( about 8"x14") attached in front of your radiator. If you have this, great, if not, get one. You can even go to the local junk yard and get a good used one. The shop will clean it and install it. You will find that the Caravan is a great functional van, but it has its.."quirks". Keep checking this site for info. Theres a lot of knowlagable Dodge owners here that can be very helpful. Good luck!
Old 03-14-2005, 11:52 AM
HiRez_L HiRez_L is offline
Re: 1997 Dodge Caravan oil change
Changing the transmission fluid isn't all that hard, there are detailed instructions here:
http://www.allpar.com/eek/atf.html
I have done it on several vans, I use the flush method from the cooler line. Make sure and use only the correct Mopar ATF fluid.
Old 03-14-2005, 01:45 PM
Thanks for the information jawss (and HiRez_L). my van has 157000km on it right now. congrats on driving your van to such high kms! I plan to do the same as far as it allows me to. I will change the oil and filter myself (Castrol oil and Fram oil filter?)
For transmission oil change which shop do you normally go to. I am in ON, Canada. should I go to mr transmission or any other that can do a reliable work.
Old 03-14-2005, 02:55 PM
Which fluid to use depends on the year, 99 and down are ATF+3, 2000 & up are ATF+4.
Old 03-14-2005, 04:03 PM
I am not sure which transmission it has. How do I check for that.
Old 03-14-2005, 04:08 PM
evictor evictor is offline
If your gears are 1,2,d,n,r you have three speed
If your gears are 1,2,d,OD, you have four speed
OD is overdrive.
Old 03-14-2005, 05:24 PM
Thumbs up
yes it has 1,2,d,n,r gears on it.
Old 03-24-2005, 11:47 PM
which power steering oil to use for 97 caravan. any specific brand/type is required.
Also how good are Pennzoil engine oil filters. saw them at walmart
Old 03-25-2005, 09:28 AM
For pwr steering fluid I use ATF oil. If you want to use pwr steering fluid, most any kind will do. Rule of thumb for any oil;the cheaper the price the cheaper the quality.Penzoil filter should be fine.
Old 03-26-2005, 01:14 PM
Re: Re: 1997 Dodge Caravan oil change
Menards (if you have one around you) has Quaker State for .69 per qrt.
Old 03-27-2005, 11:57 PM
yoji6365 yoji6365 is offline
My 98 manual specifically states not to use ATF for PS.
Old 03-27-2005, 11:58 PM
Are you planning to flush the PS or just topping it off?
Old 03-28-2005, 11:49 AM
just top it up.
