replaced cap,rotor,coil no start
replaced cap rotor ign module pickup coil still wont fire put very small amount of gas down throttle body still no start so i dont think its a fuel pump
Re: wont turn over
did you check for spark at the end of each plug wire?
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: wont turn over
What are we working on here? year.... model.... engine....
won't turn over or won't start? big difference! What happened before you had problems? stop working all at once or progressively got worse? |
Re: wont turn over
has spark 96 blazer
Re: wont turn over
hard start but would turn over
Re: wont turn over
Will it start with carb spray or ether? A "very small amount of gas" probably wouldn't start it, depending on how much a "very small amount of gas" is to you.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
Re: Re: wont turn over
thanks for your help i put a batt. charge overnight started right up :
Re: wont turn over
Where is your voltage gauge reading?
Is just above 14?
Re: Re: Re: wont turn over
Re: Re: Re: Re: wont turn over
I can practically kill my engine spraying carb or TB cleaner through the butterfly.
