Old 01-22-2005, 09:16 PM
civicdemon91 civicdemon91 is offline
Send a message via AIM to civicdemon91
Exclamation Need Help Asap
ok i own a 91 civic dx hatch an i swapped to a d16y5 motor don't talked shyt but ok i haven't done a mfi swap yet an i got the p28ecu an obd0 to obd1 conversion harness will it run fine?with the old pfi inejection system i mean the old system?
Old 01-22-2005, 09:19 PM
Re: Need Help Asap
dfi excuse me
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Need Help Asap
if the dpfi manifold bolts up to it then it should work. idk how fine its gonna be because you will lose lots of hp but it should work
Team Lonely Drivers
Old 01-22-2005, 09:22 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: Need Help Asap
your gonna need the stock ecu for dpfi ...cant use obd1 with dpfi need to leave it till you do the mpfi swap... pm5 i think was the dx ecu ..you need to use that with dpfi and distributer and stock harness. i hope it all bults up...
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 01-22-2005, 09:23 PM
Re: Need Help Asap
allright kool thanx how the wiring look if i may ask ?
Old 01-22-2005, 09:24 PM
Re: Need Help Asap
motor swap was done old dizzy an mani bolted up fine
Old 01-22-2005, 09:25 PM
Re: Need Help Asap
like a stock DX look in the link in my sig...look for under hood pics it all should be the same if you use dpfi
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
Old 01-22-2005, 09:27 PM
Re: Need Help Asap
dude u got aol holla at me so we can talk dreammachines90
Old 01-22-2005, 09:51 PM
Re: Re: Need Help Asap
http://www.fourthgenhatch.com/index2.html
look under technical / how to ...and under "Engine (Swap and related...) " click MPFI Wiring http://www.fourthgenhatch.com/mpfi.html or just click on that link
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
