Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 01-21-2005, 11:11 AM
grand grand is offline
Cold starts
Hello.
1990 Grand Marquis with 5L engine.
When below freezing the engine will start but it is extreemly rough and you must hold the pedal down a little or it will stall. At -5 deg C. it might take 30 seconds to clear and behave normally. At -15 C it might take 4 minutes but it will after that run smoothly. After about 15 minutes of normal operation the engine will begin to race. Nothing I do will stop the racing. I just have to drive like that which is of cource unacceptable.
I assume it is a sensor. Any Ideas?
Old 01-21-2005, 08:49 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Cold starts
Not sure about which sensor would be doing that, but cold temps will bring out the problems in a vehicle. Might want to have someone do a computer diagnostic on it for you while it's cold, that may give an indication of the problem.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-23-2005, 05:39 PM
Re: Cold starts
I got a code 31 which is AGR valve position sensor voltage too low. I will do some tests on that and let you know what you find out.
Old 01-23-2005, 06:24 PM
6502dude's Avatar
6502dude 6502dude is offline
Re: Re: Cold starts
In addition to EVP (EGR Value Position) sensor, also look for trouble with PFE (Pressure Feeback EGR) sensor and wiring to these sensors.
If you have hard fault, try wiggle test on cabling to sensors.
Old 01-28-2005, 06:05 PM
owo2 owo2 is offline
Send a message via Yahoo to owo2
I have the same problem and here is what I do........
Turn ig. key to on........wait 5 seconds........depress accelerator 1/2 inch......crank engine.........and then hold accelerator for a few moments to keep fast idle up........
Yours stalls like mine does because the fast idle off a 20 degree (or colder) cold start does not engage........if the motor has been off for a few hours, like overnight..........I have a 91 GM with the 5.0.......
Old 02-15-2005, 03:49 PM
Re: Re: Re: Cold starts
I have replaced the EVP sensor. There was an improvement but the weather warmed up too much.
I did a restance test on the Coolant temp sensor and it is out of limits at cooler temps. I want some cold weather to test the first fix.
