OBX SPARK PLUG WIRES (10mm)
I was just wondering if these wires are pretty good or not ? Would u recomend them ?
I recommend either MSD about $ 90
or even better Nology Hotwire $125+ |
Get MSD's or NGK's, both are $65 a set.
unless you have an aftermarket ignition you'll be wasting your money on any wires you buy other then stock.
which msd ignition do you think would perform best?
depends on what you want, you could switch your car to a DIS system or you could just get regular 6a or 6aL. if you got the cash and you go to the track a lot get one with a two stage rev limiter.
heres my opinion if you just want a capacitive discharge ignition then get a 6a if you want a better ignition with the ability to lower your stock rev limit (which im doing because the stock limiter is poop) then get a 6al if you want a track ignition then get the two stage rev limiter model (dont kno what it is off hand) as far as msd's sci series ......its worthless to pay the extra 20-30$ for it because its only a 6a and 6aL rebaged and priced higher to take adavantage of the sport compact car industry. and it comes in a cool silver box!!! wooohoooo! i think they say its designed to handle import cars that rev high...hmmm... thats interesting because a regular 6a is good to like 10,000 rpm....which you'll never see unless you own a bike. as a side note. there is basically no reason to upgrade your ignition unless you have some sort of pre existing problem, need multiple rev limiters for the track, are running boost of some sort, or have high compression, even then the gains are negligable at best. hondas factory ignition is quite able to handle the task in its stock form. |
Thanks you just saved me a few hundred bucks!! So then if wires are useless...do you know of any sites that sells colored wires that aren't so expensive...??
