Old 12-26-2004, 03:53 PM
keerus's Avatar
keerus keerus is offline
Send a message via AIM to keerus
tips on launching a 98 Z28 M6
would anyone like to describe their launch procedure? i went to the track, albeit for the first time, and my 60' times were in the 2.6-2.7 range. i just can't seem to hook up, i spin through the majority of first gear. any advice would be greatly appreciated.
1998 Chevrolet Camaro Z28
Black, t-tops, 6-speed
Modifications:
SLP Loudmouth exhaust
COMING SOON: I'm not sure
Track best:
Going to the track this weekend!
Old 12-27-2004, 10:10 AM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: tips on launching a 98 Z28 M6
Damn. Don't get anxious. That appears to be your enemy.
I was in the 2.5 60' range my first time out. Now, on street tires, I get 2.2's. Takes practice.
Are you trying to warm up street tires?? If you are, don't. Just chirp them once to clean them off. I was launching from about 2,800 RPM's, and trying to drag the clutch out a little bit, just dumping would get a ton of spinning.
Hope that helps some, good luck!
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 12-27-2004, 03:39 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
get some drag radials.
Old 12-27-2004, 05:48 PM
Genopsyde's Avatar
The President
I asked a buddy of mine who has an M6 and this is what he said...
"The RPM really depends on how much the rear end can handle. But being there is a traction problem, the lower the better. Before I had the drag radials, I would launch at 2500, roll it off the line and then nail it. The tires would still spin but would recover fairly quickly though. With the drag radials, I have launched at 4500 and with the new cam and 12-bolt, I will be launching at 5000."
Old 12-27-2004, 06:00 PM
dandyl dandyl is offline
sounds like too many ponies for youre tire sellection...do you warm youre tires up first or start cold? if so heat them up a bit besides rubber smells good and see if they stick better when hot..
Old 12-28-2004, 08:35 AM
Mr. Luos's Avatar
Firebird Guy
Re: Re: tips on launching a 98 Z28 M6
Street tires perform worse when heated. Slicks and DR's are better warm.
Stock'ish'
Old 12-28-2004, 09:02 PM
sykotic1 sykotic1 is offline
surprised noone mentioned it but you can deflate your tires a bit. id be careful but a bit cant hurt.
Old 12-29-2004, 07:36 AM
LT1MAN LT1MAN is offline
Banned
you just gotta find that sweet spot in your clutch that has the perfect balance to get you completely off of the clutch-fast-without spinning the tires. if you have piece of shit tires then you just have to compensate with less throttle, but its all about the footwork.
