Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
  #16
Old 03-22-2005, 01:25 PM
hot_red_z28 hot_red_z28 is offline
Send a message via ICQ to hot_red_z28 Send a message via AIM to hot_red_z28
Re: '94 LT1 Never-ending problem
any updates?
My Project Write-Up
Old 03-24-2005, 05:44 PM
2fast4me 2fast4me is offline
Thumbs down '94 LT1 Never-ending problem
No updates....no money at the moment to investigate this further. Car's been running really well lately though. Go figure!!
Old 04-28-2010, 09:01 PM
motoman.5150 motoman.5150 is offline
I had same thing, try the temp switch in the water pump !!!!!!
Old 05-13-2015, 10:00 PM
cliffno350 cliffno350 is offline
any updates? I am having sim problems with a new 95 caprice 4.3 lt1 and I am leaning to the temp sensor in the water pump too...
Old 05-14-2015, 10:51 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
This thread is over a decade old, it is very probable that everyone involved have moved on.
It would be best to start a new thread, so that others can find it and reply.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-14-2015, 09:09 PM
Tech II Tech II is offline
Also, the LT1 is not a 4.3, it is a 5.7.....
Temp sensor in the water pump?
As stated, start your own thread with it's own unique symptoms.....
Old 05-14-2015, 09:53 PM
Thanks keyboard king II, peeps in motor cycle forms are nicer, my v8 says on the radiator housing that its a 4.3l v8 and as I look at the motor I can see the water pump and the opti spark distributor behind it. So instead of telling me I don't know what I have do the nice thing and tell me what you think it is?
Old 05-15-2015, 10:41 AM
silicon212's Avatar
Confoundingly Lucid
LT1 is 350/5.7. The engine you have is an L99. Sometimes called a 'baby LT1'.
It would be more helpful if you lost the attitude - nobody wants to waste time with someone who is a complete jerk.
Old 05-19-2015, 09:00 AM
j cAT j cAT is offline
what you have is as silicon says is the L99... so you need to start working on what you have with this engine. I would subscribe to ALLDATA and find out whats going on, then post any questions you have. also a 1994 has some different parts on it than later models.
being this old parts finding will kill you, along with repair tech stupidity. soo even though you will not work this you best know much about this vehicle before you have some repair shop changing parts at your expense guessing why its screwed up..
Old 05-19-2015, 11:35 AM
Thanks j cat, I'm doing the work so I can only blame myself and I have 95, I may found problem the fuel pressure is jumping all over and finally dropped to 10 psi yesterday and she won't run but was giving the intermittent fault before got to the non start state. May be that hose in the tank but I have a new pump already just in case. No serv engine light at all.
Old 05-19-2015, 01:29 PM
good you have a 1995. the fuel pump on these is with a power switch on the oil pressure sender. these can cause problems on fuel pump power to pump....
fuel pressure is 41-47PSI key on engine off. engine on pressure drops down to 38PSI area. this is because at idle , high vacuum to the fuel regulator drops the fuel rail pressures.
what may be bad is the in tank wiring as well. the fuel tank must be at all times above the 1/3 mark. the in tank fuel level sender reports more fuel on dash than you really have . the pump motor and wiring connectors over heat then the pump gets a lower high resistance connection. when you open the tank and see burn't looking wires at the connectors this is very common at this age point.
check the wiring in the trunk. this is driver side, also the ground in trunk driver side as these wires supply power to tail lights and pump. open connectors look for bad pins. the heavy wire goes to the pump. then you have the under rear license plate pump connector to measure for voltage there. key on engine off voltage will be about 11 volts not 12 volts because the wire has some resistance that drops it down 1 volt or so to 11volts..
check out this video https://www.youtube.com/watch?v=MO6ofN8ZJBc
The Following User Says Thank You to j cAT For This Useful Post:
cliffno350 (05-19-2015)
