Old 09-13-2004, 09:44 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Thumbs down Dash LEDs don't work.
The LEDs for the shift indicator and the milelage decided to go black.Anybody have this problem before?This is on a 98 ZR2 and the rest of the lights work and the gauges too.
Old 09-13-2004, 10:03 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Dash LEDs don't work.
Check for a blown fuse.
LED's for mileage and shifting?
Can I see a picture of this.
Old 09-14-2004, 05:24 AM
I don't think it would be a fuse considering the rest of the cluster works.As far as a picture of the LEDs,did I mention that they didn't work now?Besides I think your S10 has the same setup,the LEDs are green in color and read P-R-N-D-3-2-1 and of course you know what milelage looks like.Can't describe it any better than that.
Old 09-14-2004, 05:27 AM
No Blazerlt your S10 doesn't have it.Just watched the video after you dumped water in your engine.
Old 09-27-2004, 11:10 PM
thejacobhartman thejacobhartman is offline
try removing your cluster and check all your connections. the display is not led's but a flourescent diplay. if that doesn't remedy it and you are handy with a soldering iron, open it up and check the connections around the glass portion on the bottom. the display is lit up by a dc voltage with an a/c reference. if either one of these lines is broken it will go dim
Old 10-03-2004, 09:36 PM
Well it came on for a couple of weeks and now is out again.These lines you talk about.Are they part of the circuit board or are they part of the hundred that rise up the display?
Old 10-04-2004, 01:22 PM
check them right where the display meets the board, there and where it plugs into the harness is where connections usually go bad. i have had to swap my whole cluster due to water and and found one for 50 on ebay. the mileage was close but i had to fill out a sticker and put it inside the dooe with the mileage at the time i took out the old one and what it was on the new one
Old 10-04-2004, 07:08 PM
Thanks I'll check it out.
Old 10-06-2004, 07:48 PM
Checked it out today.It was the wiring harness plug.Thanks.
