Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 09-06-2004, 10:42 PM   #1
tigerfreak36
Send a message via AIM to tigerfreak36
Unhappy 94 lumina apv rough running
my 94 lumina apv was running fine then i went through a pretty big watwer puddle during a hard rain it still ran fine but the next day i started it but now it misses at idle and higher speeds im not sure what to do any help? thanks
tigerfreak36 is offline   Reply With Quote
Old 09-07-2004, 01:24 PM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: 94 lumina apv rough running
Spray the coils, plug wires, module, and anything else electrical with WD-40 (it won't hurt anything under the hood) and see what happens.
jeffcoslacker is offline   Reply With Quote
Old 09-08-2004, 09:23 PM   #3
tigerfreak36
Unhappy
Well I Tried That And It Dint Do Anything However Someone At Work Told Me It Might Be My Throttlposition Senser
Old 09-09-2004, 12:03 PM   #4
richtazz
stupidity should hurt
richtazz's Avatar
I hope you didn't suck water into the engine, because you may have hydrolocked it and bent a connecting rod. I would check compression and see if you have a cylinder low, if so, you have big problems. The TPS wouldn't be affected by going thru water.
richtazz is offline   Reply With Quote
Old 09-09-2004, 07:43 PM   #5
tigerfreak36
Talking very strange
well guys thanks for your support however i came home from work today and it was running shitty well i went to the store and for some reason its running like a champ again damn go figure lol i dont understand but im not complaining now to fix a sticking caliper thanks much Rick
Old 09-12-2004, 10:40 AM   #6
jeffcoslacker
Re: Re: 94 lumina apv rough running
Back in '93, when the floods were drowning us all in the midwest, I towed a new Infiniti to the dealer, the guy had drowned it in floodwater, trying to drive through a closed intersection (duh...). When we got there, the service manager came out and tried to crank the motor, it sounded like a 10 gallon metal drum fulla rocks rolling down a hill. He threws his hands up and started swearing. He said he had 7 of them in the shop just like that, and showed me the cold air intake ducts coming from down low on the front below the bumper. They pick up a solid shot of cold water, and when the motor tries to compess it with hot pistons, the light alloy domes shatter, and destroying the cylinder bores, too. He said he loved the look on these idiots faces when he tells them that it is NOT covered under warrantee.
Old 09-12-2004, 10:43 AM   #7
jeffcoslacker
Anyway, that's why I said WD-40 soakdown. Usually if the problem is water vs. electrical in nature, the WD will eventually creep into wherever the water is, and chase it out.
Old 03-24-2005, 03:33 AM   #8
katlee
Thumbs up Re: Re: 94 lumina apv rough running
I just learned something new thank you... this is one I will remember!
Kat
katlee is offline   Reply With Quote
