Old 06-28-2004, 09:49 PM
96camaro 96camaro is offline
OverDrive and Drive
hey,
Which is better for normal driving, OD or D?
I read the owner manual. it says stick with either OD or D, while D have more power and less fuel economy ability though. Well, i am throwing it to the floor..
Which mode is best for normal driving?
Old 06-28-2004, 09:50 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: OverDrive and Drive
OD... has a lower gear which means lower engine rpms which means better gas mileage
Old 06-28-2004, 09:52 PM
and i mean by lower gear is it has a lower final gear
Old 06-28-2004, 09:54 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I'd keep it out of OD under 55mph cause you have lower line pressure which puts undo stress on the OD band when under 55mph.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 06-28-2004, 09:57 PM
$hit... I have been driving in OD for months! The reason I am asking this is that I just got a tranny code of 1870, and I wonder did i over-heat the tranny when I have been drivng in OD at all time. Well, 1870 mostly points to valve body damage, but who knows....
Old 06-28-2004, 09:59 PM
Dober89 Dober89 is offline
Driving in OD under normal conditions wouldnt be the problem. If you were doing something like driving up a long slope, and the tranmission kept upshifting to 3rd and then dropping into OD constantly, that would create alot of extra heat and stress.
Normal driving its fine.
Old 06-29-2004, 12:44 AM
Lord_Vengeance's Avatar
Lord_Vengeance Lord_Vengeance is offline
I was wondering the same thing. I've tried driving in both, and didn't notice any difference. I think I've been driving mine in OD for a while now, too.
There's nothing like biting off more than you can chew, and then chewing anyway.
Old 06-29-2004, 12:53 AM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
When you Drive in "D" instead of "OD" you are using only 1,2, and 3. Watch, slam the gas in OD while cruising, it will downshift... now while cruising shift from OD to D, same thing... the tranny is labeled OD, D, 2, 1... each keeps from shifting higher than marked gear, D is the same thing as 3 in some cars.
Old 06-29-2004, 02:35 AM
GTStang's Avatar
Stang Guy
Re: Re: OverDrive and Drive
Driving in OD under 55mph with the low line pressure will take years before it would add up to make a difference. The only thing you would notice is that you have no OD anymore but all the other gears would still work fine. It's just from a constant slow slippage of the OD band cause there is not enough line pressure to fully clamp the drive hub. It just adds up over the years.
Old 06-29-2004, 07:35 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
when talking about trucks, i would agree with GTStang, however with cars, and modern SUV's the transmission is designed to be operated in OD, thats where i always run mine, unless i downshift to pass or something, then right back into OD.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-29-2004, 09:46 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
i got a quick question here....ive been drivin in od in my truck for years. would it be bad to start driving in drive or should i just stay with overdrive?
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 06-29-2004, 10:04 PM
89IROC&RS's Avatar
when i say truck, i mean like box truck, or moving van, that has a push button overdrive, any car with OD in the gear selector was designed to operate in that setting in normal day to day driving, the transmission automaticly (huh, guess thats why its called an automatic ) picks the best gear from all available. as you move the shifter down you simply remove top gears from the available options.
