Old 06-06-2004, 10:41 AM
pez pez is offline
Low Clutch
i have a 97 cherakee limited, the clutch pedal was biting at the half way point, then suddenly droped and bit near the floor.Pumped it for some time and it was back to half way again. Now it has droped again and cant get it in to gear at all if engine is running. Is it the clutch or one of the cylinders(fluid in resavoir is full) any ideas would be a help as a clutch is very dear in uk.
THANKS IN ADVANCE
PEZ
Old 11-08-2004, 12:32 PM
SGT Rock SGT Rock is offline
I have a 1991 Jeep Cherokee 4.0 that is having similar problems. I left it in storage for over a year when I went to Iraq. Now that I am back, the clutch perdal acts funny. When it is cold, I have to pump it up to get it to get enough play in it to get it into gear, after using it a while it acts well enought to drive fine. I have bled it and ensured the fluid level is full. I ASSUME it is the slave or master cylinder, but I can't find any leaks, and there doesn't appear to be any air getting into the system.
Old 11-09-2004, 08:28 PM
95xjsport 95xjsport is offline
Send a message via AIM to 95xjsport Send a message via Yahoo to 95xjsport
Re: Low Clutch
It sound like you slave cylinder is bad, I had a 92 ford explorer and had similar problams, a new slave cylinder fixed it.
Old 11-11-2004, 11:27 PM
bmwilson's Avatar
bmwilson bmwilson is offline
Send a message via Yahoo to bmwilson
Re: Low Clutch
My 89 had this issue as well, but before I got it home it blew one of the lines. Age and old fluid I would guess, replaced the $20 dollor line after flushing all the old fluid out, and now it acts new.
Old 11-15-2004, 05:48 AM
Cam7 Cam7 is offline
Try Bleeding the slave cylinder have somebody pump the clutch pedal and hold open the bleeder valve just like brakes. Try a couple of times and check the fluid level. If no go probally a bad slave cylinder or possible a bad master cylinder.
Old 11-15-2004, 12:34 PM
dima4855 dima4855 is offline
Re: Low Clutch
have you tried to gravity bleed it?
If that does not work change the master cylinder, I had the same problem, then I changed my master and the clutch was perfect.
Old 11-15-2004, 05:46 PM
paulsenior paulsenior is offline
how to
I have a 91 XJ Sport, where is the bleeder valve, how do I find it?????
Old 11-15-2004, 06:35 PM
Re: how to
it's hanging of a hose that comes out from the slave cylinder in the bell housing
